Question about Car Audio & Video
Subwoofer help Hi, i was wondering why my subwoofers aren't working properly. Everything is connected properly, the bass is working but then when i put up my volume the bass goes away so when i decrease the volume it comes back right away
  • mindi07 Dec 07, 2007
    I think thats fine but like for example im driving and the music is playing at volume 20. The bass is there,but then i go up to 24,so now the bass will go deeper but the bass cuts off and music still plays. I have to lower vol level to get bass back. im confused dont know why it does that
    Sergeant:
    Champion:
  • 231 Answers
Hard to tell whats causing this .Just curious make sure speaker wires going to subs are POLARIZED meaning positive from amp is with positive at woofer and NEGATIVE is with negative at woofer.When these are crossed and when volume is raised you will hear the bass cancell each other out..
Posted on Dec 07, 2007
  • crispin melchor Dec 07, 2007
    ohh okay ..thats better info than your previous..check the ground wire to amp .make sure its not on top of paint from car.make sure ground is to solid metal .Also you could adjust the gain properly to amp .first adj amp gain setting to lowest.then turn radio volume as high as it can get without distorting sound .Then touch it down a pinch .Then go to amp and raise amp gain up until amp cuts out .Then touch down a pinch .then your amp and radio are gian adjusted...
My subwoofer cuts out when their is only talking and there isnt any music or bassy stuff and stays off, once the music and anything that has bass starts up then it will come back on maybe its a setting...
You don't mention the sub model. Many have a setting for automatic response in the presence of a signal. You could try teh alternative to auto, maybe Always On.
Jul 22, 2011 | Audio Players & Recorders
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
It comes on but no base sound and wont turn up
You have to fill in the details about what you're feeding it (the source and how IT's set up). It won't just >>create<< bass.
From the manual:
If you used the high-level (speaker) inputs and there
is no sound from any of the speakers:
• Check that receiver/amplifier is on and a source is playing.
• Check that powered subwoofer is plugged into an active electrical outlet and is switched on.
• Check all wires and connections between
receiver/amplifier and speakers. Make sure all wires
are connected. Make sure none of the speaker wires are
frayed, cut or punctured.
• Review proper operation of your receiver/amplifier.
If there is low (or no) bass output:
• Make sure the connections to the left and right “Speaker
Inputs” have the correct polarity (+ and –).
• Make sure that the subwoofer is plugged into an active electrical outlet and switched on.
• Adjust the crossover point.
• Flip the Phase Control switch to the opposite position.
• If you are using a Dolby Digital/DTS receiver or processor, make sure that the subwoofer adjustments on the receiver/processor are set up correctly.
• Slowly turn the Level Control clockwise until you begin to hear the desired amount of bass.
If you used the line-level inputs and there is no sound
from the subwoofer:
• Check all wires and connections between receiver/amplifier and subwoofer. Make sure all wires are connected. Make sure none
of the wires are frayed, cut or punctured.
• Make sure that you have configured your receiver/processor so that the subwoofer/LFE output is on.
Apr 07, 2010 | JBL PB12 Subwoofer
Subwoofer not getting max bass
try using a ohm meter and if its not making what the factory specs are its most likly it will keep loosing more and more power then stop working which is what ive had happen to me before
Mar 11, 2010 | Fusion RE-PK2120 900W Bass Pack: Amplifier...
Subwoofer does not turn on when playin usb or cd or aux
I have the same problem..Have you guys sorted it yet?
Mar 12, 2009 | Car Audio & Video
Subwoofer wont work
Receivers often have the ability to switch off the subwoofer channel. Especial if it wasn't connected before. If it has the ability to do a speaker test or set up try that. If it bypasses the subwoofer that will confirm the channel is not on.
May 22, 2017 | Aiwa AV-D58 Receiver
Sony sa-w305
Hi bob,
yes I have the active subwoofer book, SA-W305 1998
If you let me have an e-mail address, I will scan and send you copies (8 pages) regards Brian.
P.S. I have been using the unit on its own, just connected to my new tv, and the bass improvment is fantastic.
I had to have the amp TA-VE150 repaired,by having the IC joints resoldered, due to overheating.
Aug 17, 2008 | Sony SA-W305 Subwoofer
Help
Hi Cassie, unless your receiver is a surround reciever, it won't have an actual subwoofer output. The good news is that you can use either a "line out" jack or a "tape out" jack instead, which most receivers do have. These jacks always have the signal, so there are no special settings to remember - simply operate your receiver as usual. Everything comes out of these jacks, not just the bass - but it won't matter since your subwoofer will only reproduce the bass frequencies. The bass information is generally identical in both left and right channels, so either the right or left jack should work fine, and it's okay to leave the other one unconnected. The only bad thing is the line and tape outputs are not affected by the receiver's bass and treble controls, so you'll have to control the bass volume at the subwoofer if it has a control. If you can't control the amount of bass you hear, turn up the volume and reduce the treble which will give the illusion of more bass. I'm assuming you have "powered" subwoofer (has its own built-in amplifier). Good luck!
Jun 22, 2008 | Bose Acoustimass 15 System
Cerwin Vega V-10S Subwoofer doesn´t sounds good
dear "rai17"
This, to me, is most likely the voice coil inside the driver rubbung against the yolk plate, or possibly the spyder slapping the metal plate underneath it, or the amp-(if it has one?) getting tired. this can occur from poor build quality, or playing the subwoofer too loud. depending on how much it cost you, you may want to get it repaired(voice coil re-alignment or something or new amp). But the way it seems, it is probably the driver itself. subwoofers get looser as they break in. This one may have been over-broken....sorry
I hope this helped clarify what is happening!
Oct 09, 2007 | Cerwin Vega V-10S Subwoofer
Car Audio & Video Logo
164 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
