Question about Mr. Coffee APX33 Coffee Maker
To set time
How do you set the time on the mr. coffee APX33?
  • 24 Answers
If your model comes with the delay brew function,simply hold time button until flashing then scroll with hour and min buttons until time is set
Posted on Dec 06, 2007
2 Suggested Answers
  • 3 Answers
SOURCE: I have Mr Coffee APX33;
First you have to make sure to set the clock for the correct current time:
Press down and hold the SET button. Then alternately press the UP and DOWN buttons (indicated by arrows), until you reach the current time, then release the SET button. (there is a PM indicator on screen but not an AM indicator - if you don't see the PM you are at AM)
To set the time for the brew to start in the future:
Press and release the MODE button once and the Delay Brew Clock picture will start flashing on the screen.
While the Clock picture is flashing - hold down the SET button while you use the UP and DOWN arrow buttons to set the desired brew time (you can hold down an arrow button to get there faster). Release the SET button and now that brew time is programmed. (After a few seconds the clock picture will disappear but the future brew time is programmed.)
To activate the delayed brew:
Press and release the MODE button once. The Clock picture will be flashing and the time shown will be the time that you previously set for the future brew). While the Clock picture is flashing - press and release the BREW button. The Clock picture will remain on steady. The BREW light will not come on until the time in the future that you have programmed.
Pretty confusing - but it does work. Just remember that if you see the Clock picture on steady - the machine will come on at the time you have set in.
If you want to use the machine earlier - while the Clock picture is steady - you just press the BREW button and it will brew.
If the Clock picture is steady but you want to cancel the automatic future brew - just press the BREW button twice. (This turns it on and then off and cancels the future brew).
I can send a copy of the manual if you like. Lennyg678@aol
Posted on Apr 10, 2011
How do I set the timer on my Mr. Coffee model BVMC-EHX23 so that it stays hot 2-4 hours?
Hold the set delay button while changing the hour and minutes to your desired time. The coffee maker will only stay on for 2 hours as it has an automatic shut off.
Oct 02, 2015 | Mr. Coffee Coffee Makers & Espresso...
The water tank on my APX33 leaks water everywhere how can I fix it?
This model has spring loaded valves and seals that are pretty weak. There is also a heat problem that can warp the tank-to-base connection. I fixed mine by wrapping some teflon pipe joint tape around the outflow portion of the holding tank to augment the seal when the tank is in place. But you won't be able to remove the tank while it has water in it if the spring seal is also bad. I just add water to the tank as needed using the carafe or something else.
Sep 03, 2012 | Mr. Coffee APX33 Coffee Maker
Need to set my mr coffee to brew at a certain time
Hi Val: There are a number of 12 cup Mr Coffee models. Instruction Manuals in PDF can be found listed here:
http://www.mrcoffee.com/InstructionManuals.aspx
Thank you for using FixYa!
Oct 20, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
All I need is the manual to my Mr.Coffee Pot how to set the timer to Mr. Coffee GBX23.
First set the clock on the brewer with the unit plugged in. Press and hold the Hour and Minute buttons until the current time is set. Next press the Delay Brew button while using the Hour and Minute buttons to reach the time you want the coffee to begin brewing.
Set up the coffee maker with ground coffee or beans and sufficient water in the reservoir then follow the directions below.
For brewing with fresh ground beans, press and hold the Delay Brew button until it flashes then press Select once. The Grind and Brew light should come on and the Delay Brew light should become steady.
For ground coffee, press and hold the Delay Brew button and then press Select twice. The Brew Only light and the Delay Brew light should both be on and steady.
Most Mr. Coffee product manuals are here: http://www.mrcoffee.com/InstructionManuals.aspx . The direct link to the GBX23 manual is http://www.mrcoffee.com/Manuals/MANUALS/GBX23_43_50118420.PDF .
I hope this helps.
Aug 20, 2011 | Mr. Coffee GBX23
I have Mr Coffee APX33; I do not know how to set the coffeemaker to turn on automatically. I do not have the manual. Hope you can help. Thanks! Larry
Sep 17, 2010 | Mr. Coffee APX33 Coffee Maker
Need instructions how to use preset timer on aroma 12 cup coffee maker
I never really use this coffe maker. someone gave it to me. and i am not sure how to set the timer to have the coffee ready when we get up in the morning.
Aug 26, 2008 | Mr. Coffee APX33 Coffee Maker
Brew Station Deluxe Model 47454
unit needs cleaned run a 50/50 mixture of white vinegar and water through it a few cycles and then a few cycles of clean water this should remove any deposits in it. this should fixya!!!
Dec 11, 2007 | Mr. Coffee APX33 Coffee Maker
Will not program mr coffer IS [times] 43
Your coffee maker is still under the manufacturer's one year warranty. Contact Mr. Coffee for the nearest authorized service center in your area. You can take the unit or send it to the service center, they send it back to Mr. Coffee, and then Mr. Coffee send a new unit directly to you.
Oct 14, 2007 | Mr. Coffee FTX24 12-Cup Coffee Maker
Mr. Coffee APX33 Coffee Maker Logo
185 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
