Question about Canon PowerShot S70 Digital Camera
CAnon s70 Camera opens 1/2 way and then does nothing else except beeps when moving the slider to try to close or press the take picture button. E18 does appear on the screen along with black horiontal lines.
  • Anonymous Mar 28, 2014
    A black line has appeared about half way down the viewing screen and it goes half way across screen. The line is thin black but has other tin lines above and below it about a quarter of the way along it. This line has just appeared today.
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
When my S2 IS is turned on, the lens moves out, a beeping sound occurs, but the viewfinder remains black except for the message E 18. The lens does not move back in when the off button is pressed.
The Error E18 is quite a havoc on these Canon cameras. Here is a blog with great info on it: E18 Blog
Do not force your lens back into place and don't try and jiggle it either, you will be further damaging other pieces.
This camera is very powerful and the repair is well worth it. Teleplan Camera Repair provides a quote online with the cost clearly displayed.
Aug 04, 2010 | Canon PowerShot S2 IS Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
Canon powershot s410 problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Aug 20, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Canon s50 display problem
Hello there,
Jun 28, 2008 | Canon PowerShot S50 Digital Camera
Lens cover slide stuck closed
Take a butter knife and slide it where the crease is. move the close/open button till it open it could just be stuck due to moisture. Hope this helps.
Mar 09, 2008 | Canon PowerShot S70 Digital Camera
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD200 E18 Error
The "E18" error code indicates an error that involves the lens unit or lens cover. The grinding noise you hear-to my regret- means that len's mechanism is malfunction. This type of problem could be fixed by professional only.
Jun 23, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon S70 does not work
Canon Technical Support is the next place to go. This is a firmware error- maybe not a correctable problem except by replacement
Jun 15, 2007 | Canon PowerShot S70 Digital Camera
PowerShot A70
This comes up when the lens sticks. Try removing the colar around the lens, then turn the camera on/off and give it a "little help" to open or close, it's probably just a little stuck
Dec 14, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot S70 Digital Camera Logo
174 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
