Question about Mitsubishi WD-52725 52". Rear Projection HDTV
No digital inputs on the menu
On the device menu the digital inputs are gone!!
  • vimac Dec 06, 2007
    Thank you very much :) It worked
  • 1,153 Answers
Initialize settings by pressing "menu, 2, 4, 7, 0 enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the netcommand and tuner settings. 2. (Initialization and reset does not help) Suspect the DM PCB part # 934C116002
Posted on Dec 06, 2007
My vizio tv turns on but had no display
Check to make sure the device you're trying to use with your TV is plugged in and turned on. While it may seem like a silly oversight, it is possible that you switched on your TV and didn't actually turn on your DVD player, gaming console or whatever device you're trying to enjoy. If you tried to use a remote to turn on the device, check that the batteries still have a charge and turn on the device using its built-in power button.
TIP The problem may be your input device itself. Check your TV with other devices and see if it displays them properly. If it does, contact customer support for your device for more detailed troubleshooting instructions
Make sure that your TV is on the right input channel for the device you're trying to use. When your TV isn't switched to the right channel, no visual or audio input from the device will display on your screen or through your speakers. Turn on the input device and press the Input button on your remote to cycle through your input channels until you see the device's display on your screen.
If you're on the right input channel and your device is turned on, there may be a problem with the physical connection between the device and your TV. Make sure that all cable connections are secure, and also that all cables are connected to the In ports on your TV and the Out ports on your input device. If you're using a connection that has color-coded plugs, make sure the connectors are inserted into their appropriate color-coded ports.
If you're using an HDMI connection, make sure that the cable you're using is compliant with High-bandwidth Digital Content Protection, especially if your TV and input device are both HDCP-enabled. HDCP is a copy protection system that prevents the copying of digital video and audio content as it travels over the connection. Systems connected with non-compliant cables won't display any video or audio conten
Periodically a TV may freeze up, showing that it's still turned on but not actually displaying any information from your input device or the TV's menu system. To fix a freeze, power cycling is the best solution. TEP 1 Turn off the TV by pressing and holding the Power button on the cabinet until the TV powers down.
STEP 2 Unplug the TV from the wall power outlet.
STEP 3 Press and hold the Power button on the cabinet for 30 seconds, and then release it.
STEP 4 Plug the TV back in and turn it back on using the Power button on the cabinet or your remote control.
If everything is correctly set up, powered on and on the right channel and you still aren't getting any picture or sound, there may be a hardware or software fault in your TV. The best way to check is to press the menu button on your TV or remote and see if the on-screen menu appears. If the menu doesn't appear, contact repair
Sep 28, 2016 | Vizio SV Televison & Video
Just switched to digital in Denmark & lost my channels.What can I do?
look at the input devices in main menu .you might have to select cable as input
Feb 11, 2016 | Televison & Video
The SIGNAL: ANALOG won't disappear even though I've gone through the menu and selected my input OPT: CD/DVD/TV whatever it may be. How do I get my optical input recognized by the receiver? Is it broken?
It will change automatically once it detects a suitable digital signal.
So yes it could actually be faulty but more likely you aren't sending a suitable format digital signal from the source. check the digital audio output settings on whatever device you are using
old dvd players will output PCM 2 channel digital or bitstream multichannel (dolby dig or DTS) which your unit can handle whilst new blurays will have some very hi bit rates -eg192khz 24bit. You may need to lower the output in the menus to get the Pioneer to accept them.
It is always possible the optic has got kinked or fractured, which causes light scattering/corruption and will cause the same symptom
Sep 04, 2010 | Pioneer VSX-D411 Receiver
System check says can't be inputted into memory
On the device goto menu (by holding "ok") then sub menu then format.
a on device format should fix it.
May 15, 2010 | Olympus DS-40 Digital Voice Recorder
I have a Mitsubishi Model VS45603. We lost power
You will have to select the TV Menu (on the remote), go to NET COMMAND, and reassign all your devices and inputs again. You may even want to go to SETUP first to be sure the screen, video, audio, color, is what you want before assigning devices to inputs.
Aug 11, 2009 | Mitsubishi Televison & Video
The screen went dark on jmv 111
Dark as in gone or dark as in the image is still viewable?  How does the onscreen menu look when the image is dark/gone?  If the onscreen menu looks right and the image is still dark, you might want to check the cables or another input.  If another device using different cables and another input looks fine, you may only have a problem with the input/cable you are using to view the movie.  If the onscreen menu is also dark, then I would think there is an internal problem that needs looking into.
Mar 23, 2009 | Jensen Car Audio & Video
Cannot change my Mitsubishi WS-55615 to switch from 480 to 1080I
You cannot change the setting on the TV itself. you need to go through the settings on the equiptment you have plugged into the TV to change their settings to display a different resolution.
Sep 15, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Digital optical
You must go in to the menu on your amp and select the optical input for that device. Most are default rca but it is a simple change.
Jan 26, 2008 | Sony DAV-S400 System
No video
I am not sure if you have gone into the Receivers Menu or not? If you have NOT! Then please try this: Go into the Receivers Menu (If you do not see the MENU on the TV you can hook up a Composite (Yellow) Cable from the Receivers Monitor Out (Yellow) and select the Input on the TV that you plug into) Look in the Menu for Inputs or In/Out Config. or Video Setup. Look for the Input that you are using for that Device. Change the Video setting to HDMI. I also recommend doing this for you Audio as well. Find the Audio Inputs and MATCH each Input to there DEVICE and CABLE (Connection) Being used. Also check in the Receiver Menu for UPSCALE or UPSCALER. Turn this on or off to see if your TV is Compatible! Hope This Helps! P.S. Check the Manual for Upscaling Capabilities NOT all Receivers upscale and route the SAME!
Jan 12, 2008 | Yamaha RX-V861 Receiver
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
