I think it might have over heated, does this have a protection mode? If so how Do I get it working again? The lights still turn on and Im pretty sure it is still providing power, but the subwoofer isnt doing anything.
Comments:
Aug 30, 2009
- Im pretty sure its the JVC KSAX4504 MOSFET 600-Watt Amplifier, and its powering one 10" sony xplod.
Aug 30, 2009
- It ended up being the sub and not the amp, the amp works fine. The sub had some wiring issues and has now been replaced, thanks for the fast response though.
Yes it has a protection mode, let it cool for while then try it again, if it over heats quick make sure you're not running the amp below its stable impedance.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Very helpful
" - yummster
Popular Solutions for JVC KSAX4504 MOSFET 600-Watt
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to...
(More)
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to have the best sounding hit from the subs?
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1...
(More)
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1 sec works 2 sec doesn't work, etc...). Power led is on, as have to be. Sometimes works OK. So, where the problem is ?
ok....my amp had a couple parts that were fried...(a couple capacitors and two of those chip looking...
(More)
ok....my amp had a couple parts that were fried...(a couple capacitors and two of those chip looking things. i forgot what they r called.) anyways I was told by some tech that as long as the part num (ex. RFP50N06...which is the actual num.) are the same, the new chip would work. The amp still does not work. now the old chip has the serial num on top of another num...( H9 ) now the new chips i bought has the serial num (mentioned above RFP....etc)below another code that shows " F 1G23SF. now does that make a diff, n if it does...where can I buy the actual "chip" or resistor or whatever it is called
on my 2010bxi i accidentally touched the positive to the negative input for a split second and now...
(More)
on my 2010bxi i accidentally touched the positive to the negative input for a split second and now neither the power nor protect lights come on, but a faint blue on top does still come on. what exactly is wrong and how can i repair it?
