Goodman CLJ30AR32 Air Conditioner
Problem for Goodman CLJ30AR32 Air Conditioner
AC unit outside blowing out cold air, vents
By ntingale74 on Aug 30, 2009
AC unit outside blowing out cold air...a lot of cold air. House is warm, vents shooting out warm air
Comments:
Aug 30, 2009
- Gas furnace. Not only is the fan outside blowing out cold air, it seems to be louder or faster than usual. Turned the unit off until repairman can come. Just have fan running.
Clarification Request
Posted by meBNme on Aug 30, 2009
Is your system a heat pump or a gas furnace?
Best Solution
posted on Aug 30, 2009
Helpful)
vi_llur_ca
Rank: Guru
Rating: 92%, 146 votes
If you have a heat pump probably there's a wrong connectionin the thermostat, but if is not a heat pump ,the compresor is not working or the unit leaked all the refrigerant.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" thank you, we have had a problem in the past with refrigerant leaking, was supposed to be fixed " - ntingale74
Solution #2
Helpful)
hitekfirst
Rank: Wiz
Rating: 81%, 31 votes
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Was this helpful?
Yes
No
Asker's Testimonial
" sounds reasonable and a job for a professional " - ntingale74
Popular Solutions for Goodman CLJ30AR32 Air
Questions and Unsolved Problems for Goodman CLJ30AR32 Air
Do you recommend Goodman CLJ30AR32 Air Conditioner?
Answer
Answer
i have an air conditioner Samsung AQV12VBA. It does not operate on the heat mode. Error code... (More)
Answer
i have a PAC CT90 portable AC with a drain hole located at the bottom back -- but i can't get... (More)
Answer
I recently posted a problem with a GE Zoneline heatpump. Model AZ32H12D3M1 works fine in the summer... (More)
Answer
I have a goodman GSC140361AE unit My highside is at 75 and my lowside is at 30 I try to ad a freeon... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
