I have a samsung RM255LASH refrigerator. THe fridge part is working OK . but the freezer just went berserk and is functioning @ 50 degrees. It also has another problem, @ the bottom of the freezer compartment usually a solid sheet of ice is puddled up.
Have a look at page 29 to page 34, the section titled self diagnostic's which will explain how to get the system to perform various self checks.
There could also be another section of interest on page 20 and page 31.
I'm not trying to make you **** lemons when you read these sections as they talk about operating controls but I'm just making sure that you havn't accidentally turned something off by accident.
Feel free to have a browse through but there iis a lot of information regarding how to take the fridge apart which i really doubt you need to do or would want to do.
Two problems I think.
How to check
everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
AND
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Was this helpful?
Yes
No
Popular Solutions for Samsung RM255LASH Side by Side
I change my water filter, and when I try to reset the change filter indicator light on the front...
(More)
I change my water filter, and when I try to reset the change filter indicator light on the front door, after touching the light for 3 seconds the light never change colors.
Lost power to the house but when power came back on, the control panel flashes with 98 on the left...
(More)
Lost power to the house but when power came back on, the control panel flashes with 98 on the left and A8 on the right. can not control or reset panel
ice not dispensing and the frozen food and ice are slowly melting.... fridge part is okay..this is...
(More)
ice not dispensing and the frozen food and ice are slowly melting.... fridge part is okay..this is for the samsung quattro..thanks
Samsung RM25 Refrigerator. Display flashing 88 88 to 98 99. The second 99 is actually reversed....
(More)
Samsung RM25 Refrigerator. Display flashing 88 88 to 98 99. The second 99 is actually reversed. (Lower right segment not flashing but I don't have that key on this keyboard). I cannot find the error codes on line for this unit. Ice Off, Light and Child Lock indicators lit but unit will not allow me to reset it. Water and Ice levers still work and unit is cooling. Unit has been unplugged for 10 seconds and power reapplied. Any thoughts appreciated.
