The movies on one ABC HD channel come in spanish audio. The commercials are in English audio. All other channels, both HD and not, are in English. It doesn't matter how I change any settings, nothing fixes the problem.
interesting! Sure you are not connected to a dedicated Espanol station? I have tried to emulate your problem but cannot succeed I can only recommend you try to tune that channel manually to another number and see if it still does it.
I was watching TV and the screen went black. I turned the tv off and on and its still black. I also...
(More)
I was watching TV and the screen went black. I turned the tv off and on and its still black. I also heard a low buzzing sound from the back, has the bulb burned out?
TV turns off after 5-10 min. Replaced the bulb about 2 months ago. Couldnt reset the timer because I...
(More)
TV turns off after 5-10 min. Replaced the bulb about 2 months ago. Couldnt reset the timer because I don't have the original remote. Lamp Light has stayed on and message comes on when turning on TV. Now the tv stays on 5-10 minutes and then powers down like sonmeone shut it off. You can turn it back on again without unplugging but same thing happens. Does this have something to do with not resetting the timer or is the bulb going bad or is it something worse?
TV was working fine this morning. Turned it on this afternoon and no picture. Green power light...
(More)
TV was working fine this morning. Turned it on this afternoon and no picture. Green power light comes on and flashes. TV makes a faint rapid clicking noise that might repeat a few times.
pink dot in the middle of the screen about the size of a softball on shows up with light colors on...
(More)
pink dot in the middle of the screen about the size of a softball on shows up with light colors on the screen
