Question about Sony Ericsson W850i Cellular Phone
Help w850i wsod
Screen flashing white!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • jitesh Jan 16, 2008
    the problem i am facing is the screen turns white whenever i switch on my phone...
    i have tried changing the slider film but it still doesn work
  • Anonymous Apr 13, 2008
    i had the flashing white screen,changed the flex and the upper keyboard.the screen came back on but the up,down,left,right buttons did not always respond,this was also a previous problem.then the next day trying to get the up button to respond by pressing it a few times the scrren turned red and green.i turned the phone off,when i went to turn it back on it would not boot up and just starded with the flashing white screen caper again
It is true, flashing white screen is caused by faulty upper keypad circuit board. The connection between this board and the flex cable must be tight , else you will get WSOD.
If your upper keypad is crack, most likely you will damage the keypad circuit board after some time.
i finally fixed my WSOD on w850i after trying flashing of firmware, gdfs restore. WSOD is definely a hardware problem
Posted on Sep 18, 2008
My phone got same problem it hapen just when i was usin photo dj and making a fun pticher the screen trund white. when i restart phone its still whit but som times for me it becoms normal but then when i go to meny all white and music all white. And when my alarm starts its no white and when i put it in my computer its not white but when i use it is white.... Somthing wrong with the Display?
Posted on Apr 16, 2008
Replace the upper keypad, in mine there was a crack in one of the connectors on the bottom side of this keypad!
Posted on Apr 12, 2008
    Brigadier General:
  • 7,752 Answers
Have the flex cable replaced....
Posted on Jan 16, 2008
Sony ericsonwi just on only by white screenplease help and sugest me thanking u
It is commonly known as WSOD (White Screen of Death). A DIY solution is not possible and you will have to take it to the nearest service center where they will flash your phone.
Jan 19, 2011 | Sony Ericsson P990i Cellular Phone
I need the W850i LED circuit diagram...
sir;
i have sony ercsion modil w850i.its lcd showd white;sir i changed the stip and key pad and lcd but my problim is not solve what the problim is it plz u help me your obediently;
Jan 28, 2010 | Sony Ericsson W850i Cellular Phone
White screen and no picture
Could be two things, try these in oder.
1- upgrade or Flash your phone with the latest firmware. you can get here
2- Change your flex cable
that should solve your problem
Dec 01, 2009 | Sony Ericsson W850i Cellular Phone
White screen on sony ericsson w850i
Several solutions for white screen on se w850i
-Solution white screen with hang problem = reflash with the same CID firmware.
-Solution white screen ,but can make a phone call =
replace the flexible cabel or / and lcd.
Nov 22, 2009 | Sony Ericsson W850i Cellular Phone
Wsod on samsung e250 (white screen of death) onlywhite screen when on charge .Wont switch on. I suspect Rom Firmware problem???
it may be rite wat u r suspecting...........other problems can be like software problem which u will have to flash via connectin to a system........ or very least possible is that it might be your display problem also...........which u can easily get repaired
Nov 03, 2009 | O2 Samsung SGH-E250 Cellular Phone
White screen which keeps flashing problem
Hello and Welcome to FixYa!
Common problem know as WSOD (White Screen Of Death)
The only solution is to Flash the Firmware, BUT Note that when you turn your phone on, IF there is a pluse vibration (Just for a sec) THEN this solution will work.
The whole solution is well described in this article, again let me clear you it is a 100% working/tested solution, I'v done it successfully many time, but as you are a newbie, so throughly read the article before continueing and if you got any confusion, DO ask me here by posting a comment.
If I was helpful, kindly do Rate!
Regards, Waqar.
Oct 05, 2009 | Sony Ericsson W300 Cellular Phone
White screen se w850i
If restarting the phone several times does'nt work the phone needs to be flashed, noting is wrong with the screen seeing that there was no accident all you need to do is find a phone mechanic and have hm flash your cell phone its sure to work again
Jun 15, 2009 | Sony Ericsson W850i Cellular Phone
Faulty w850i
Are you sure you have flashed it correctly? I had a white screen problem and flashing fixed it. Make sure both your main and fs firmwares are the same type eg W850_R1ED001_FS_VFE_LIVE_1_RED52
W850_R1ED001_MAIN_GENERIC_CY_RED52
and your custom pack can be any w850
Dec 03, 2008 | Sony Ericsson W850i Cellular Phone
White screen problem
if the phone is white sreen then you should try replacing the flexcables on the phones or the LCDS
Oct 14, 2008 | Sony Ericsson W550i Cellular Phone
WHITE SCREEN ON W850I
Take the phone and ahve the lcd replaced
Jun 26, 2008 | Sony Ericsson W850i Cellular Phone
Sony Ericsson W850i Cellular Phone Logo
436 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
