Question about HP Compaq FS 7550 17" CRT Monitor
7550 brightens intremittently
Can anybody help me with my7550 monitor problem? the thing is that sometimes the brightness goes up when i've turned on the pc but when i check the settings the brightness is where i left it. it turns real bright that everything is washed out. i got this monitor firsthand and ive been using this for 3 yrs now. is it age? when it operates normally fonts are still crisp, its just that lately this "brightening" happens. the cable is secure at the back and the power plug is secure on a ups.
  • 749 Answers
Some component might have loosen up on the circuit of your monitor! cleaning inside and resoldering loose components could fix your problem!
Posted on Dec 06, 2007
How to add more backligth to Dell ultra Sharp 190FP 19" LCD monitor? The frontside brightness is full, still the monitor is dimm.
Hold down (Fn) key and press, press, press.... right arrow (----->) the right most key on your keyboard until back light brightens. If you press several time it also goes off. Just press again until brightens.
Have fun
Jun 16, 2014 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
I have a 7550 and the screen lights up but the menu does not come up - I have replaced the batteries. It was working when my sister gave it to me a couple of months ago.
Okay....I don't know if this will help, but this is one thing I learned about my Pfaff 7550. Sometimes it will look like the screen is lit up but there is no menu or anything and I have found that the "display lucidity control" dial is the problem. If you look just below the buttons that are in a semi-circular shape, you can see a really tiny little dial. It can be easily missed if you don't know where to look. What I have found is that sometimes the screen lights up but there are no words/menu and if you turn the "display lucidity control" dial, the words/menu will appear. As my machine has gotten older, it seems I need to do this more often. The first time it happened to me, I freaked because I thought the display (even though it was lit up) had blanked. THAT was when I discovered that teeny little dial that solved my problem. I don't know if this is your problem, but give it a try and see if works for you like it did for me. And by the way, if you need to see a diagram of the buttons on the Pfaff 7550, here is one. The "display lucidity control" dial is marked #23 http://www.manualowl.com/m/Pfaff/creative-7550/Manual/333556
Apr 05, 2014 | PfaFF Sewing Machines
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
I am using a compaq 7550 computer and on the monitor i turned the brightness down to about 80% i tried pushing the + button to turn it back up too 100% and it says it already is at 100% though i know it is...
OK, ITS A RELIC CRT MONITOR.
OVER 16 YEARS OLD? TODAY.
why not do like all others did back in 2010 upgrade to LED LCD
frankly your lucky it glows at all and not catch fire.
unplug it from the wall
for say 1hr and try again.
lock might happen.
like this, enter the 21 century bold and new, and hope.
https://www.walmart.com/search/?cat_id=3944_3951_1230331_1230336&query=computer+monitor&sort=price_low#searchProductResult
Jan 31, 2018 | Compaq FS 7550 17" CRT Monitor
MY ACER MONITOR IS DIM , HOW DO I BRIGHTEN IT UP?
Push the button on the front that says menu. Within that menu you will find the brightness control. Use the other buttons to move through the different menu items until you get to Brightness. Once there push the menu button again and then adjust the brightness with the other buttons.
Nov 27, 2009 | Acer AL1916W 19" LCD Monitor
No image but only a bright white horizontal line on the middle
Be it a LCD or CRT monitor, in either case, the screen is gone. Either service or replace.
RDO
Nov 17, 2008 | Compaq FS 7550 17" CRT Monitor
Compaq 7550
swede32169,
Try the buttons on the front or side of the monitor to get to the menu using the + or - to maneuver Thu the menu items until you see the "sun" that's for brightness the half filled circle is for contrast that helps too.
randy320sgi
Aug 13, 2008 | Compaq CV 7500 17" CRT Monitor
Monitor settings
Have you checked the actual board that has the buttons to see fi there is an issue there?
If you've found nothing there and still experience the issue, sounds to me like you might be looking at a bad micro.
Nov 21, 2007 | HP Compaq FS 7550 17" CRT Monitor
Usercontrol automatically displayed when bootup
Please change the switch pannel  and check
Nov 19, 2007 | HP Compaq FS 7550 17" CRT Monitor
Monitor
Is there still power to the monitor or is the screen just black? Do you hear any sort of sound when it goes black? Does the time the picture goes out vary or does it happen after say "X" minutes/hours everytime? Do you have any power saving software activated that would cause the monitor blank out? Check display properties? Sounds weird but have you checked for any viruses or spyrus nasties? If its hardware it could be many different things. Let me know what happens. Good Luck Tim
Mar 15, 2007 | Sony CPD G420 19" CRT Monitor
HP Compaq FS 7550 17" CRT Monitor Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
