Question about Dell A940 All-In-One InkJet Printer
Dell AIO printer A940
Hi
My sensor came out and I think I put it back - but now the printer won't print and it sounds like the cartridge is moving back and forth?
ERRO 50C
Catridge is not show black only plz slove the problem thanks to your reply after your msg.
Posted on Dec 22, 2007
ERRO 50c
Lexmark A940 (AIO) - The cartiage is showing
1. The cartridge may be dried up.
2. The cartridge contacts in the printer may be damaged.
3. Mechanical interference prevents print heads from moving.
If your cartridges are rather new but have not been used recently (a few weeks or so), they may be dried up. You can test this by removing one cartridge and applying rubbing alcohol to the nozzles. Let it sit this way for a few seconds and put it back into the printer. If your test page shows some streaks instead of nothing, that is your problem.
Open the printer cover. If the print cartridges move to the correct location for replacement, there is not mechanical interference. If the motors make noise but the cartridges do not move, there may be an obstruction in the printer. Try to clear it.
If neither of these are the case, try replacing the cartridges with genuine Lexmark cartridges certified for your printer. If this does not remedy the situation, your printer's contacts or other components are damaged. In this case replace the printer.
Jan 24, 2010 | Dell A940 All-In-One InkJet Printer
The printer is printing blank pages.
STEP 1: Disconnect and Reconnect the Printer Power Supply
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
STEP 2: Run a nozzle clean on the Dell A940 inkjet printer.
To run a nozzle clean, perform the following steps:
1. Click the Start button, point to All Programs, point to Dell Printers, point to Dell AIO Printer A940, and then click Dell Printer Solution Center.
The Dell Printer Solution Center menu appears.
2. Click the Maintenance button.
The Maintenance window appears.
3. Click the Clean to fix horizontal streaks button.
4. Click the Print button.
The Nozzle Clean function prints a page.
5. Check the Nozzle Clean Printout to verify that it is free of defects and that all expected color bars exist on the page
STEP 3: Restore the printer settings to factory default
To restore the printer settings to factory default, perform the following steps:
1. Click the Start button, and then click Control Panel.
2. Click Printers and Other Hardware.
3. Click Printers and Faxes.
4. Right-click the Dell Printer icon, and then left-click Properties.
5. Click Printing Preferences.
6. Click to select Save Settings.
7. Under Restore, click Factory Settings (Defaults).
STEP 4: Clean the Contacts and Wick the Ink Cartridge
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
1. Ensure the printer is powered on.
2. Lift the scanner unit.
3. Open the cartridge latches and remove the cartridges from the carrier.
4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Note: Never wipe the cartridges from side to side, as this causes cross-contamination in color cartridges.
Cleaning the Contacts
1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
2. Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible.
Note: Do not use the same cloth that was used to clean the cartridge nozzles. This may cause more contamination on the cartridge.
3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
4. Replace the cartridges in the carrier and close the scanner unit.
5. Print the document again.
6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Then run again STEP 2. If the printer still prints in blank pages, contact Dell Technical Support. They may need to replace the Ink Cartridges.
Jul 02, 2009 | Dell A940 All-In-One InkJet Printer
Dell A940 AIO won't print & shuts down
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
Hardware error:0502
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Apr 05, 2008 | Dell A940 All-In-One InkJet Printer
Dell AIO A940 printer and Vista.
Starting ******* and doing drugs, screw this era. I hope the whole entire thing crashes!!!!!!!!!!!!
Mar 21, 2008 | Dell A940 All-In-One InkJet Printer
Dell all in one printer 940
try holding the power down for 15 seconds
Mar 06, 2008 | Dell A940 All-In-One InkJet Printer
Black cartridge not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Jan 15, 2008 | Lexmark X75 All-In-One InkJet Printer
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
