Question about Marantz RC5400 LCD Touchscreen Remote Control
Screen Calibration My screen wouldn't respond to touch so I re-installed the firmware. Now it requires calibration but it fails every time. Any ideas?
  • 3 more comments
  • jujur Jan 17, 2008
    I have same exact issue. Any suggestions/solutions
  • seanus713 Jun 18, 2008
    exact same problem...
  • Anonymous Aug 27, 2008
    Same problem ..need help
  • hhousman Sep 08, 2008
    my screen will not respond to touch
  • Kenneth2488 Nov 30, 2008
    screen won't respond to touch. Tried new firmware but calibration fails each time
I'm a french customer with a Marantz RC5400 wich has a screen LCD broken but the touchscreen is OK
I don't have the fix for your problem but I'm searching for a screen replacement at low cost...
If you always have your Marantz with the touchscreen problem, I'm interested for a deal
Thanks
Posted on Aug 25, 2008
Touch screen not responding
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
Mar 12, 2014 | Ricoh Office Equipment & Supplies
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
My iphone screen cant touch ?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Apple iPhone Smartphone
Samsung a897 touch screen not responding at all
Hello there,
On the other, it might be the screen is weak and needs calibration. To calibrate the screen depends on the type of phone it is. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Caseytech
Jun 27, 2011 | Samsung Star GT-S5233 Cell Phone
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
Screen Calibration problem with SteetPilot c330
Turn off the unit. Then hold down the power button for about 1 minute and the calibration screen will eventually come up.
Nov 30, 2007 | Garmin StreetPilot C330 GPS Receiver
Touch screen calibration
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
Touch screen does not work.
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Jun 18, 2007 | Garmin StreetPilot 2620 GPS Receiver
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Marantz RC5400 LCD Touchscreen Remote Control Logo
725 people viewed this question
Top Marantz Televison & Video Experts
Marvin
Marvin
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
