Dual Electronics CECT P168 Cellular Phone Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot connect sciphone to iwireless internet and sms
I just got megatalk yesterday and the text messaging worked just fine.
I messed with a number which was aparently the wrong thing to do. My SMS is not working anymore.
I also cannot get connected to the internet. I need to know what the settings are.
I have been looking on the internet and cannot find out what to do.
Please help
Trisha
Level 2:
Scholar:
  • Expert 173 Answers
  • Posted on Aug 30, 2009
Trisha
Expert
Level 2:
Scholar:
Answers
173
Questions
0
Helped
53170
Points
429
You accidently deleted your sms provision number. Call your service provider to reset your settings. Dont call on your cell though cause they will need you to turn the phone off.
Hi. I inserted my sim into my iPad but cannot receive SMS
You cannot receive SMS sent to the SIM in your iPad. SMS are sent over the voice network, not the internet. And your iPad does not connect to the voice network. If you have a data-only SIM, your carrier should not be sending SMS to that number. This means it can't be used for phone calls or Short Message Service (SMS) text messages without installing an additional app. If your clients and business colleagues use Apple iOS devices, including the iPad, iPhone and iPod Touch, you can send and receive text messages using iMessage, which is already on your iPad. https://support.apple.com/ipad
Jun 14, 2019 • Cell Phones
2answers
My mms messages do not send on my curve 8520, they try to send for a long time then show it failed to send, i tried sending to myself and that did not work
This could only be caused by a couple of things. The message center number in the handset may not be correct, which will cause the messages to fail. The other possibility is that the feature is not active on your account with your wireless provider. What you need to do is test a couple of things. See if you can send a text/sms message to yourself, in doing this you can verify that you can not only send, but receive text/sms messages. If you cannot send, or receive text/sms messages, then that verifies that the message/service center number is off, and will need to be corrected. If that works, and you can receive text/sms messages, then your service center number is correct, and you will move to the next troubleshooting step, which is to test your web browser. If you cannot launch the web browser on your handset, then this is an issue, because the MMS service requires that you have both SMS, and web browser service to send a MMS message. If you can access the internet and you have the ability to send/receive text/sms, then you need to call your service provider as the issue may be with their service.
My sciphone will not receive text messages
not recieving sms on my sciphone
2answers
I cant recieve text on my sciphone i can send them fine but just wont recieve what settings do i need to change?? (im on the orange network)
There is a code that needs to be input in a specific area to do so. Ask your seller for the correct number or u can can get it from your service provider. Ask them the number the SMS messages connect through.
69helpful
10answers
I can not send SMS message. SMS Message Center Number Error
I had the same problem and came to this site for help but the solutions didn't solve the problem of "cannot send text message" on htc touch hd. All service numbers correct. Went to START/SETTINGS/CONNECTIONS/ADVANCED NETWORK/SMS SERVICE then changed from "gprs" to "gprs preferred". Double checked and had reverted to "GSM" but sms now works - finally!!! Hope this helps.
4helpful
2answers
"Check Operator Services" when sending a text
most probably you have disabled the CLI thing. In which your cell tries to prevent your number being shown to the person you are calling.
It is usually under Network settings, or Call settings (CLI/Show my number/Send my Number).
21helpful
4answers
Sciphone I68, service provider ATT, GPRS not subscribed
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Just be Patient and make sure you double check everything you put it it has to be exactly as it says.. I just set mines up yesterday and it works fine.. Hope this helps! It took me forever to find the solution hah
1helpful
5answers
I cant recieve my text messages using my sciphone i68
first off need to know what cellular provider you are using, 2nd all text or picture text. regualar text is classified as SMS pic text is MMS. You may have a corrupt setting, but ill take a guess and post T Mobile setup. if you use someone else dont use these settings.
SMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap SMS on the Messages menu.
3.) Tap SMS settings on the SMS menu.
4.) Tap either SIM1 or SIM2 on the SMS settings menu, whichever SIM you are setting
up at this time for SMS messaging.
5.) Tap Profile settings on the SIM1(2) message settings menu.
6.) Tap on any unused profile to select it, then tap the Edit button on the bottom of the
screen.
7.) You should be on the Profile name menu with the name field already highlighted. Go
ahead and tap the Edit button at the bottom of the screen.
8.) Tap in the following text between the quotes in the Profile name editor:
“T-Mobile”
Next tap the Options button at the bottom of the screen. Next tap the Done button.
You should be back on the Profile name menu with the new name.
9.) Tap the area below the profile name. The top of the menu should change to read SC
address and the bottom of the screen should show a numeral keyboard.
Tap in the following text between the quotes in the SC address editor:
“+12063130004”
Next tap the OK button at the bottom of the screen.
10.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
You are done setting up SMS messaging for T-Mobile. You can continue
to tap the Back button on the bottom of the screen until you exit out of all
the menus to the main screen, or simply press the On/Off button once to
get back to the main screen. At this point you can test SMS messaging by
sending yourself a text message, or continue with other setup of the
phone.
MMS Messaging:
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
at this time for MMS messaging.
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for “HTTP://”, then tap in the
following text between the quotes after the HTTP://
“216.155.174.84/servlets/mms”
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
“8080” to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact [email protected] Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
2answers
`I do not accept sms
your msg center number must be missing digits so you will have to call your mobile service center......and have them assist you
Top Dual Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
john h
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
