Question about Hotpoint RB757 Electric Kitchen Range
HotPoint Electric Stove
Oven and stove top elements do not work and it is not the fuses.
  • Big Tom 2 Jan 06, 2008
    stove top burners do not work all the time. I have checked everything. Is there some kind of circuit breaker in the stove that will re-set itself?
  • Anonymous Mar 18, 2009
    that oven the burner always in low tempture it iscan change the tempture
  • 126 Answers
Check your breakers check your cord make sure you have 220 volts at service block
Posted on Dec 10, 2007
2 Suggested Answers
  • 198 Answers
SOURCE: Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Posted on Feb 20, 2009
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
My Maytag Performa glass top stove does not work. The oven doesn't heat up but the stove top works fine. I checked my fuse box downstairs and it is fine. I checked the stove to see if there were any...
Dear Gina,
It should be one of 3 things.
1) The element has burned out, or
2) The socket the element plugs into has failed, or
3) the wires hooked to the socket have toasted.
Someone must take the stove apart to see.
God bless your efforts.
Oct 26, 2017 | Maytag PER5710 Performa Electric Kitchen...
Stove top and over don't work
check that you have 240 volts at the wall also ensure that it is wired correctly the oven elements run on 240, if the voltage is ok you may have a bad board
Jan 07, 2010 | Hotpoint RB787 Electric Kitchen Range
All stove top elements and oven wont work
Go to your home circuit/fuse panel and reset the fuse or circuit breaker for the range.
Dec 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Self cleaning hotpoint stove
Sometimes in self clean it can burn out the element.  Need to check the element with an ohm meter and see if it shows resistance.  If it shows open then the element is bad.  If it shows resistance then the element is ok.  Next see if you are getting 220 volts to the element when in bake mode.  If you are not getting 220 volts then the control is bad.
Oct 20, 2007 | Hotpoint RB757 Electric Kitchen Range
Hotpoint RB757 Electric Kitchen Range Logo
314 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
