Question about GE Profile JT952 Electric Double Oven
Broken inside glass of oven door
Hi - I have the part, I have a picture of the parts of the door. Is there an easy way to get the door off? GE wall convection oven Thanks
Lee
I have the same broken inside glass problem. The frame is bent also. I also need to know how to remove the door. I think I will need to take it off the repair the dent but I might be wrong! Should I just remove the frame first to determine if it can be repaired. Could you give me a reference as where to get the best deal on parts. Thanks.
Rob
Posted on Jun 30, 2008
  • 833 Answers
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
Posted on Dec 07, 2007
The inside glass (between the inner and outer glass of the door) of the upper oven door of my GE JT952-30 shattered during a baking cycle. I need the replacement part number and a possible source.
Hello would need the entire model number as you can see by this link there are 32 models of that oven http://www.searspartsdirect.com/partsdirect/part-model/JT952?searchModPar=JT952&pathTaken=modelSearch&prst=0&shdMod=JT952
you can either message me back and I will then pick which is your unit then you would go under door schematic and it would bring up the diagram for your unit which when you clicked on door it would being you to this blown up view of the door this is an example http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Wall-oven-Parts/Model-JT952BF7BB/0432/0125300/G0510389/00005?blt=06&prst=&shdMod= and if you scrolled down to like on this schematic has the outer door glass shown as number 140 in the diagram and then underneath that it would give the part number such as it does for this one being
PART NUMBER: WB57T10259 if you have any further questions or would like me to look your model up further please message me back with the complete model number Thanks Rick
Jun 28, 2011 | GE Profile JT952 Electric Double Oven
Kelvinator F36 oven door glass measurements
you have to get high temp glass or it will shatter
May 24, 2010 | Ovens
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
I need to replace the glass door front on my GE Profile 27" double wall oven JK955. Other than the outside glass being broken the rest of the door is fine. Can I purchase replacement glass?
Yes, but i believe it comes with the door handle already attached. Full model number, upper or lower and color is needed for looking up the part number. Expect to pay $210-280
Mar 03, 2010 | Ovens
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Replace the window assembly in my GE oven door
sadly without seeing it in person , can not tell what bit you might need . they do make and sell many types and sizes .
Oct 06, 2017 | Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven door
Contact your nearest appliance store. Most have GE parts in stock. This may be more available than you think. I have seen someone take tempered glass and literally glue it with special heat resistant glue and it looked really pretty nice. The edges were beveled and not sharp. This of course is a last resort.
Feb 05, 2009 | GE Ovens
GE Profile JT952 Electric Double Oven Logo
231 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
