Question about Panasonic PT-AE500U Multimedia Projector
OUTPUT; PT-AE500U The right side of the picture is blue. The screen is 94 inches. The blue colour is in the shape of a right triangle. Almost all the way to the top of the screen and about 14 to 16 inches from the bottom right of the screen. Interfers with viewing. Any ideas
  • kinetik Feb 04, 2008
    I also have a Panasonic PT AE500E and also have the same issue. It seems to be like a burn in type affect in blue and is not in the same position everytime you use the projector. I was told it was the globe and today have replaced the old globe. Problem still there. Not happy. 2 and a bit years old and seems to have a serious problem.
    From further research online and it seems it may be an issue with the optical block?
    If so it looks like this costs about $1800 Australian dollars to fix.
    If it sounds like I am right please let me know. if I am. Panasonic never again!
5 Suggested Answers
  • 17 Answers
SOURCE: Panasonic PT-LC56E projector
that projector has not been made for some time (7-9 years I believe) so there are probably several thousand hours on the projector, and at about 2500 to 3000 hours your panels start to fail,, sounds like the LCD panels are warping, and you are loosing convergence.
that projector would cost about $500.00 to replace with a newer brighter unit, with a new warranty.
but the "E" means this unit is for europe only, so your prices may vary
Posted on Jul 17, 2008
SOURCE: Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Posted on Jan 04, 2009
S203celest
  • 20 Answers
SOURCE: I have a Panasonic LCD
your color calibration may be off. see if you can set the red green and blue settings all to "0" and see if that works. may want to refer to your manual and see how you can do that and also see if there is a auto calibration
Posted on Jan 23, 2009
  • 4090 Answers
SOURCE: I have a Panasonic PT-AE500U projector i am on my
Optical block is the culprit! replacement is not too difficult. About the only special tool required is a long phillips screwdriver to reach the screws securing the block to the front panel of the set. Then, there are three connectors on the C board which is part of the block, one connector on the left side of the C board, one fan connector on the left side and then two connectors on the lamp driver board which is on the back of the optical block. Two recessed screws hold the block to the front panel and sometimes there is a third recessed screw to the left of where the lamp is located. Then the block slides out. Reverse the procedure to install the block.
Thanks for using FIXYA
Posted on Nov 27, 2009
A trough is formed by nailing together, edge to edge, two boards 11 ft. in length, so that the right section is aright triangle. If 15 gal. of water are poured into the trough and if the trough is held...
Find the vol of the water in cu/in
15 * 231 = 3465 cu/in
Change 11 ft: 11*12 = 132 inches
Find the triangular area of the end of the trough; 3465/132 = 26.25 sq/inches
Let x = width of the trough; A right triangle area = [img width="16" height="39" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image001.jpg" alt="1%2F2" v:shapes="Picture_x0020_1"> x^2 = 2(26.25)
x =[img width="53" height="22" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image002.jpg" alt="sqrt%2852.5%29" v:shapes="Picture_x0020_2"> x = 7.2457 inches the width of each board
Find the width of the trough which is the the hypotenuse
h =[img width="69" height="40" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image003.jpg" alt="sqrt%28x%5E2+%2B+x%5E2%29" v:shapes="Picture_x0020_5"> h =[img width="110" height="22" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image004.jpg" alt="sqrt%2852.5+%2B+52.5%29" v:shapes="Picture_x0020_6"> h =[img width="43" height="22" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image005.jpg" alt="sqrt%28105%29" v:shapes="Picture_x0020_7"> h = 10.247 inches wide, also the base of the triangle
Find the altitude of the triangle, which is the depth of the water; we know it's area[img width="16" height="39" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image001.jpg" alt="1%2F2" v:shapes="Picture_x0020_8"> 10.247d = 2(26.25)
10.247d = 52.5
d =[img width="56" height="39" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image006.jpg" alt="52.5%2F10.247" v:shapes="Picture_x0020_9"> d = 5.12 inches is the depth of the water
Jul 24, 2011 | Computers & Internet
Poor picture quality,after power failure
You have a dying projector lamp. Have it replaced and the picture quality will be good as new.
Jun 08, 2010 | Toshiba 42H81 42" Rear Projection...
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
Colour has screwed up
Call Encompass Parts Distrubtion 1-800-638-3328 its either your DMD board 180.00 or Light Engine and they do not have any in stock Cost $1,056.00 Try UED 1-800-648-6657>
Dec 31, 2009 | Samsung HLN5065W 50" Rear Projection...
Projector picture cuts out for a few seconds then comes back on.
Dear,
Your projector problem on cooler is not run properly,so it goes to shutdown.Clean every surface from blowing through.Then all dust clean.
Dec 26, 2009 | Panasonic PT-AE500U Multimedia Projector
I have a Panasonic PT-AE500U projector i am on my 4th bulb now and i have a blue hue on the left side. It was on both sides, i had it sent in and cleaned and now theres only a hue on the left side. I have...
Nov 27, 2009 | Panasonic PT-AE500U Multimedia Projector
Cant get into the golden box
You have to get the gems to light up. You need to do it in the right order as follows:
1.PINK triangle at top right
2. ORANGE square bottom left
3. YELLOW pentagon top, middle
4. BLUE, bottom right
5. PURPLE top left
Montymolly
Feb 10, 2009 | Nintendo Mystery Case Files: MillionHeir...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
42 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
