Question about Western Digital (WD3200JS) 320 GB Hard Drive
Computer won't boot
My computer will not boot past the bios with my SATA HDD. All I get is a blank screen with a blinking cursor. I know all my parts work, because I put my HDD into another computer and it booted. I tried putting an IDE HDD into my computer and it booted, but it isn't mine. Also, when I try to use the Windows XP disk to reinstall, it checks the system's configurations, then goes blank. Can you help me?
  • 1 more comment
  • syroch Jan 05, 2008
    same probleme
  • Anonymous Dec 04, 2008
    I don't know if I have a SATA or an IDE hard disk. I just received it from Dell to replace bad drive. It is CAVIAR SE 320GB ATA/100. I have assumed it is an IDE drive. Does the ATA in the name indicate it is an SATA drive? I have exactly the same result as Fabian_C. Do I need to download another BIOS on another computer and install it in the computer with the new hard disk? If so, how do I get one? I can't figure this out from Dell's support pages.
  • Ekse May 11, 2010
    Does your computer detect the drive and is it set to boot from it?
  • 13,433 Answers
Make sure your computer detects the hard drive and is set to boot from it.
Posted on Feb 12, 2008
Windows wont start up when computer is turned on, at the bottom of the screen, it just says press f for set up or tab for bios memo, then the screen will be blank with just a cursor blinking
If you are interested in solving the problem more easily and quickly. I think you can try this computer boot up suite, a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jun 25, 2011 | ASUS Eee PC 1000H Laptop
Dell inspiron 531 with vista home premium, sata DVD/hdd, wont boot past bios screen, blinking cursor in top left corner. with nothing hooked up, says no boot devices available. i have tried each one solo,...
That blinking cursor is the way in which the BIOS is telling you that Windows or any other OS is missing . Since you are getting it without even an hdd connected it means that the southbridge is defective. Which means that the motherboard is dead, replace it.
Oct 19, 2010 | Dell Inspiron 531s Desktop Computer
Lenovo SL 500 not booting after startup only black screen with cursor is seen
Dude,
Most of the time, the machine booting with the blinking cursor indicates a problem with the HDD itself.
You can do the following:
1) Reseat the HDD
2) Check BIOS boot order and see if the HDD is still recognized at BIOS level
3) Load the BIOS defaults (F1 at boot, then F9, F10)
4) If the HDD is detected at BIOS, try to access Rescue and Recovery on the HDD (F11 key at boot) and try to reload Windows.
5) If problems persist, I'd highly recommend replacing the HDD!!
Apr 17, 2010 | Lenovo ThinkPad SL500 Notebook
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
Computer won't boot
I think I can help you with this. You have listed your pc as a pressario desktop. I have to make some assumptions, so bear with me.
The first is, that this computer is designed to work with IDE or EIDE hard drives.
You'll need to get into the BIOS or SETUP on the computer. Once in there (this is before the computer runs) you have to tell the computer where it will find the operating system.
There should be a heading called BOOT, and when you are under this heading, there should be a sub heading for the hard drives, and the priority given to them.
Yours should be a ADD ON CARD because this Pressario is designed for IDE (again, I'm making that assumption) and the default is to look there for your OS.
With the boot set to look at add on cards, you should be able to boot to the SATA drive.
good luck
tony
May 19, 2009 | Compaq Presario 5000 PC Desktop
Computer won't boot
hi there,
in this case you mention that it check then system configuration and then goes blank,so therefor your windows XP installer is corrupted replace your windows installer.regards and have a nice day don't forget to rate me.
Apr 08, 2009 | Computers & Internet
Won't complete the boot up
As far as the rebooting is concerned id check the bios boot order make sure it can see the HDD. You normally recieve that blinking cursor when it cant find the HDD or boot device.
Also have you tried using hte restore cd's It's a bit of a last resort effort but my guess is your HDD is dead if you attempt to run the Restore CD's and they fail it pretty much means its the HDD.
The cracking noises will be from the speaker wires either loose or touching something else causing a static type effect. Fix is to adjust wires possibly replace them. Not easy to do by yourself. Unlikely that the speakers are affecting the reboot though.
Other possibility is a faulty mainboard capacitors that will definatley rebooting to occur.
Let me know how you go with the bios and restore discs or if you need further help.
Mar 23, 2009 | Acer Aspire 5100 Notebook
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
Computer won't boot
1.  Check that the M/b will support the 160 GB HDD
2.  If it ok check the Hard disk jumper.
3.  See that the jumper must be in Primary Master
4.  Connect the Data Cable of Primary
5.  Check the jumper of any other HDD or CD/DVD roms
if your problem solves, vote me
Thanking you
Dec 19, 2007 | Computers & Internet
Computer won't boot
did you load the raid drivers?
Dec 05, 2007 | ASUS P5LD2 Motherboard
Western Digital (WD3200JS) 320 GB Hard Drive Logo
287 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
