Question about Vtech mi6896 Trio Cordless Phone
Can't answer phone
Phone rings butwhen you try to answer it, it just beeps twice. You can call out but you can't answer. Two of 4 phones having this problem. How can I fix them?
  • 3 more comments
  • schlaf9 Dec 06, 2007
    none
  • davidnolan3 Sep 13, 2008
    phone rings, when you answer two beeps, but nobody there, but it still works to call out
  • Anonymous Nov 04, 2008
    I have the same problem with 2 of 4 phones unable to answer incoming calls. It is as if they have lost their connection to the base unit. Any ideas on how to fix?
  • Anonymous Dec 08, 2008
    Same eact problem. I tried changing the battery but it did not help.
  • Anonymous Jan 18, 2009
    Same problem. I can hear the base ringing, but the handset will not connect - in fact it reads 'connecting...' until the answer macine picks up. Bizarre. I see someone changed the batteries and it didn't work. I charge mine all the time.
Mi phone indicate place in charge
Posted on Dec 22, 2007
I cannot answer the phone without pressing the incoming call button that is flashing. I want to be able to answer the phone just by picking up the phone.
From the phone, don't pick up the handset and press PROGRAM 99 then dial 22 and press STORE. Here's a problem. By default, that's what it's supposed to be and if it beeps twice when you press STORE, you didin't change it. Pick up the handset and drop it back down to exit programming.
In order to have incoming line preference, your phone has to be RINGING :-) So, if the first program didn't work, you need to see your system manager to program your phone to ring. Or find an installation manual on the internet.
Carl
May 20, 2011 | Panasonic KX T7220 Corded Phone
I recently got this old "Panasonic Easa Phone KX-T2835" from a thrift store and my phone only rings twice before my answering machine picks up. How can I make my phone wait till 4 or 5 rings before it...
Have you tried erasing all the (incoming) messages on the machine? Does that let it ring the full 4-ring-cycle before it picks up?
It's been years since I owned one of these, but there should be a switch (on the side of the unit?) for a feature called "toll saver" If you find this, switch it off.
The idea was from the days of payphones -- if the machine had no messages, it would ring 4 times before it picks up. If there were messages, it would pick up after one ring (or sometimes two)
If you were out on the town and wanted to check your messages, you'd put your dime in a payphone and call home. If it rang three times, you can hang up the payphone and get your dime back, knowing there's no message to check.
Jun 14, 2010 | Panasonic Lands Phones
Need phone to ring more than twice before going to message
CLICK HERE for your owners manual in PDF format.
However the model # is for an external handset (add-on)
The number of rings is set on the base.
Please post the Model # of the actual Base unit for help on the answering machine.
Thanks for using Fixya - a Very Helpful rating is appreciated for answering your FREE question.
Jul 30, 2009 | Panasonic KX-TGA101S Cordless Handset
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Change te number of rings
I need to change how many rings it takes my system to answer . It is set for attendant , I need it to answer after 5 rings . I need this changed because I now have a answering service that is set up though my phone provider verizon to call forward after 4 rings Lucent partner 18d
Jul 18, 2008 | Lucent PARTNER18 Corded Phone
Phone not ringing
Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
Dec 26, 2007 | Vtech VT-9118 Cordless Phone
Vtech mi6896 Trio Cordless Phone Logo
168 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
