Question about Amana ASD2326HE Side by Side Refrigerator
Water takes a while to start
Some times you have to wait 20-seconds for the water on the door to start to flow after you presss the glass into the door. You can hear what seems to be the sound of water pressure building up and then suddenly it starts. When it finally does start, the flow is normal. The longer you go between uses the longer it takes to start. The times are getting longer. I tried removing and re-attaching the water filter. The water filter is only a couple months old. Thank you.
  • clauritzen Dec 31, 2007
    The water pressure is fine. And there doesn't appear to be a leak anywhere. The problem is it takes about 14-seconds before the water starts to flow at all. Thanks for your help. ~Chris
  • 262 Answers
Put a 8oz glass upto the dispenser and start filling when the water starts the glass should be half full in 6 seconds if not the water pressure is to low if so you have a small leak some where in your tubing these are press and pull fittings usually and are located by following the line from under the door up under the ref.and back to the water inlet valve on the left rear of the machine hope this helps and good luck. oh if you have the type water valve that is up on the water line to your home make sure it is not on a plastic pipe because plastic piping will make a flap and restrict your flow
Posted on Dec 06, 2007
Water stops flowing when door is open
This is normal. A lot of refrigerators will cut off water flow when a door is open. It can be useful when you have guests over who don't know about it and start filling their glass. You open the fridge and take your time getting something while they stand there and think their glass is filling.
Jun 11, 2012 | Refrigerators
Rinnnai hot water instant gas water system does not flow for a period of about 20 seconds then works but unit makes wrirring noise before and after water is turned on or off
Sorry to read about your problem, I hope this helps you out.
This is have start up and then shutdown... in wont start flow until water heats up to correct point...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Kitchen Ranges
Brand new GE Profile GFSF6KKYCBB French Door with external ice and water dispenser. After filling a glass of water, pull the glass out and water turns completely off as expected. Two seconds later, the...
factory defective, call in warranty service
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
Water overflows from icemaker & freezes in the freezer. Makes three ice cubes in a day & the water is extremely slow to fill glass from freezer door!
If both the water in door and ice maker are experienceing slow water problems the common point is the water supply itself.
This can be caused by:
1. Water supply shut off valve is partially closed or blocked with debris.
a. TURN water supply OFF
b. Remove the water line from the rear of the refrigerator ABOVE the in line filter (if one is installed)
c. Place the removed line into a bucket.
d. Turn on water supply and check flow. It should fill an 8 Oz glass in about 8 seconds.
If it passes this test then the water supply is fine. If it FAILS this test either cflear the obstruction in the line or replace the water supply valve from the house connection.
Test 2 (Water supply is OK
Reconnect water supply to external in-line filter (If installed) or water valve assy connection.
Your unit has a Verticle filter that if it is clogged will cause slow water flow.
Test water thru the door for the same amount of water flow. It should fill an 8 Oz glass in 10 seconds or less.
If it does ot do this then the VERTICAL internal water filter is clogged. (5 months or 500 Gallon change interval)
REPLACEMENT filter is PN LT500P but there are several like / suitable aftermarket replacements for the LT500P number.
As for the ice maker freezing up. There is only one cause for this and that is the water valve assy itself is bypassing water when it is supposed to be closed. The only remedy for this is to replace the water valve. They are not repairable.
The valve is available through sears parts direct:
Thanks for choosing FixYa.
Sep 19, 2010 | LG LSC26905TT Side by Side Refrigerator
Water slowly coming out of dispenser
Is this a new Unit or a second hand unit? If it is not new... most likely there is debris in the water valve inlet or the actual saddle valve / faucett connection to the refrigerator water supply line is partially blocked.
Without a Model number to ensure the exact parts inside the unit for you to check is a bit of a problem.
Most of the water valves are the same and an example of yours would be item 10 of this link:
detailed view:
- What I recommend you do is disconnect the water supply line on the back of the unit and check 16 oz. of water flow at the end of the supply line. Water OFF before disconnecting the supply line.
- IF the water flow is the same as through the door you will need to find out why there is not enough flow from the water supply source.
- Additionally IF you have a water filter installed external to the unit... it can be clogged or full of sediment and need to be changed.
- If you discover that the water supply is of good quantity and pressure there is also the possibility of a pinched or kinked plastic water line some where inside the refrigerator.
- Sometimes the hose that passes through the door hinge flattens out and restricts water flow.
Thanks for using FixYa.
Jul 10, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Water taste and smells like mildew
Hi and welcome to FixYa. I am Kelly.
How about the house tap water same odor and taste or just the fridge?
If it is just the Fridge I am assuming your unit has been around for a while.
If you have a mildew build up in the plastic tubing of your ref it can be a tedious cleaning procedure to get it all out of the system The stuff ends up sticking to all of the plastic tubing inside the unit and is so hard to get rid of. What you can do is have all of the plastic lines changed out in the Refridgerator from the water valve outlet to the the water in door and icemaker. It is just time consuming to do it.
Water supply to unit off for the steps below.
You can try using a small baster (I use a hair dye applicator bottle) and a bleached water mix that is not too strong. I would recommend that you start AFTER the water valve in the bottom of the unit. You have got to be able to introdue enough pressure through the system so that when the water in door switch is activate that the bleached mixture will flow out of the spout. You will have to introduce the water until you can smell it in the water you get from the glass you used to catch the water. Then let it stand for an hour. Re-intorduce the same amount of bleached water as before and wait another hour. After the second mixed water bleaching reconnect the water supply and purge it at the water in door outlet with a glass.
Probably sounds a bit much but this is from experience and believe me it does take lots of time.
I am sure this is not what you were expecting but it really is the only way your going to rid yourself of the bad smelling and tasting water CURSE.
Thanks for using FixYa!
Feb 18, 2010 | Pds GE Profile Bottom-Freezer Drawer...
I have a Kenmore side by side refrigerator/freezer. I am getting really slow flow from water dispensor (outside freezer side door). It takes 20 seconds to fill up a glass of water.
check to see if your ice cubes are well formed or hollow / if hollow replace your filter 1st and if no good replace your water line / if cubes are large and well formed the replace your water valve to fix your water problem.
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Water in door takes over a minute to BEGIN flowing.
I had the same problem.... Until just one day the water quit working... Always thought it was hard water build up blocking the waterline.... Come to find out several years later all it was, was the dual water valve that had gone bad... I guess they have a censor in them that will either lock open or lock shut.... Mine was locked shut... When I tried to fix the valve myself, by opening it up and blowing air threw it, I locked it open and when I conected it back up to the fridge water was coming out of the door uncontrolably. So I ordered a new water valve.. Replace it myself... Works great now.... Hope this helps...
Apr 06, 2008 | Amana ASD2326HE Side by Side Refrigerator
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Water Dispenser
does your refrig have a built in water filter? it may need replacing. if thats ok try checking your water supply to be sure that there isnt a kinked water line. if both of those check ok you may have a bad fill valve.
Dec 11, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Amana ASD2326HE Side by Side Refrigerator Logo
97 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
