This is whats called a convergence failure. You will need to call in a repair shop or goto sites like www.TvRepairKits.com hthat ave the parts to fix this yourself. Its a common failure on projection TV sets.
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
In the menu do the auto convergence. If still bad replace the convergence ics. Also check resistors around the ics. You can remove the front grill and access the conv board from the front. Small board on the right. It popps out.
convergence ICs need replacement there are two STK392-110 Convergence ICs in that model, Also check the 2.2 ohm 2watt resistors there are 6 of them in that model.
Hi, Your question shows its Samsung rear projection TV that has 3 tubes to project picture. Symptom shows TV got problem in convergence board that will be replaced. Model number or TV would help me to provide you more info. Thanks.
Good Day; If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
