Question about Samsung DVD-H1080 DVD Player
I have bought samsung dvd player h1080 and it seems that it is region 1 how can i make it region 2. thanks
That doesn't work as the remote control doesn't have numbers on it. I have tried with a different Samsung remote and that still doesn't work
Posted on Sep 30, 2009
    President:
  • 846 Answers
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
Posted on Aug 30, 2009
    New Friend:
So far all I could find that works on Region 1 Samsung DVD-H1080R dvd players is the following.
I found, using an originally region 1 DVD plwyer the sequence to be: (with no disk in the drive)
Power On
Repeat
Fast Reverse
Next Chapter
Fast Forward
Previous Chapter
Play
(make it region 2 by highlighting this sequence: 2 7 9 10 19 21)
(original sequence is (3 7 9 19 21)
Power off and back on
Fast Forward
Fast Reverse
Fast Forward
Up
Down
Power off and on.
This worked for me, but the dvd player plays kinda funny, but is open to all regions (tested region 1 and 2 disks)
Posted on Aug 23, 2011
2 Suggested Answers
SOURCE:
SOURCE: I have a Samsung DVD player model No H1080, what
AC/DC HIGH VOLTAGE ROCKING ROLL
Posted on Jan 10, 2010
Our Samsung DVD-H1080 DVD Player wont open, we've had it for a while, but the place where it opens is stuck, help??
Are you using the remote or touch button on case to eject tray?
Sometimes the top lid gets warped and prevents the tray from opening. Press eject and lift the front part of the lid at the same time.
Aug 17, 2010 | Samsung DVD-H1080 DVD Player
I want to unlock the regional code of my player which is samsung dvd-H1080 xtl
I found a reference to guide you how to unlock your samsung player for region coding. check this link here.
Jul 03, 2010 | Samsung DVD-H1080 DVD Player
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
I need the multi region code for a Samsung DVD H1080
Sorry, there isn't one. Your model is not hackable.
The usual Samsung hacks involve using the remote to enter the correct numbers but your model has no number keypad on the remote. Substituting a universal remote also does not work and I've been informed by Samsung that the region coding on this model is hardware encoded just like on many Sony and Panasonic models so you cannot even override the coding using a service centre remote control (I've tried). I discovered this when a friend purchased a large quantity of clearance overstock region 6 DVD H1080's and asked me to convert them for resale in the UK (region 2).
To hack your model requires internal hardware replacement and this is not economically viable.
Oct 14, 2009 | Samsung DVD-H1080 DVD Player
Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
Aug 12, 2009 | Samsung DVD-H1080 DVD Player
How to unlock the samsung dvd h1080?
SAMSUNG DVD-H1080 This worked for me:
Turn on the DVD without disc in the tray
Press repeat (not repeat a-b)
Press fast forward (>> not >>l)
Press rewind (<< not l<< )
Press up
Press down
'0' appears in top right corner
turn off then back on.
Aug 03, 2009 | Samsung DVD-H1080 DVD Player
Wrong region code
Not much can be done about this other than returning to get a refund since it is Oman don't expect any joy
Aug 21, 2017 | Samsung 1000W 5.1-Ch. Home Theater System...
Samsung code
1. Cold start the player, by holding down the PLAY and STOP buttons on the player.
2. You should see a set of language options. Release the PLAY and STOP buttons.
3. Select your language.
4. Press REPEAT (not the repeat A-B button) then the following codes for the required region the player is already set to (region you bought the player in):
5. A code will appear, indicating the region setting of your player.
6. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
7. Press OPEN on the Player to open the disc tray.
8. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified.
Jul 05, 2008 | Samsung DVD-P244 DVD Player
Samsung DVD-H1080 DVD Player Logo
1,326 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
