Question about LG Electronics LRM-519 Digital Media Recorder
Unit Frozen The display shows "Hello" and flickers in time to a tiny little red light on the motherboard next to a nicad battery (observable once cover is removed on the left side of the unit. Removing or replacing the battery seems to have no effect. Pushing the little red buttons next to the light and battery make the light speed up or stop, but no other changes. No menu, no movement, no spinning up of the drive inside. Help?
  • 10 more comments
  • m iqbal Dec 08, 2007
  • Kalralahr Jun 12, 2008
    Yep, me also. Same exact problem... Will check the power supply.
  • coreyMB Sep 07, 2008
    I was Watching tv and it just stoped took off the cover flashing red light tryed to push the two little red buttons but it did nothing I need some help.
  • A John Keller Dec 08, 2008
    I bought three of these on e-bay and they all eventually had this problem.
    I changed c18 and c36 as Nipper00 posted. Both are 2200uf at 10v.
    Both units are now working. I do notice that the display is still a little dim. I can handle that as long as it works.
    The third unit "resurrected" itself after a couple of weeks of being powered off. It will die again.
    I bought 10 for less than $10 delivered from http://www.opamp-electronics.com/catalog... as posted by coreyMB.
    Thanks everyone.
  • Terrence  Jones
    Terrence Jones Jan 06, 2009
    I have the same problem. My client told me that their DVR wasn't working anymore. I have removed the the two capacitors (C18 and C36) and should recieve the replacement ones in a few days. I will post and let everyone know how everything turns out. From the looks of it, this should be a reliable fix. Thanks everyone!
  • Anonymous Feb 05, 2009
    I had a similar problem and replaced the c-18 & c-36. Now it works, but now I have no display on the unit. Dose anybody know if either c-18 or c-36 has anything to do with the display? Maybe I have a bad connection on one of the resisters?
  • Anonymous Feb 10, 2009
    The hello lite is dim, the unit will not operate. No tv thru the unit, drive door will not open. Thanks Jerry
  • jerrycrum1 Feb 10, 2009
    The hello lite is dim, the drive will not operate and there is no tv thru the unit. Red lit blinks fast. There is a green lite about 4 inches to the rear of the red lite.
    We had a storm here last nite. However all the other units on the same power strip is still working. Also have a power stableizer for the units. Tried to reset the unit with the power button. Was wondering if there are any other resets. Thanks Jerry
  • lpatrickjr Mar 07, 2009
    wondering if there was anyone in the New Jersey that can fix my unit, which is suffering from the dreaded "Hello" syndrome
  • trevit May 11, 2010
    Quote:xjnation
    "I had a "dead" lrm-519. Tried unplugging, restarting, etc. I took off the housing cover and pressed a little black button on the mother board. Fired right up and has been flawless since."
    What little black button?
  • climateau May 11, 2010
    In response to pbjy's post on Sept. 17,2008
    Your cliarification post is a little misleading...
    There are the 220uf 200v Caps on the PRIMARY power supply board at the heat sink....
    HOWEVER there are two 2200uf 10v Caps located in the Secondary section
    (located by the rainbow power cable harness) They are located at C18 and C36....
    My C36 cap is the one that is bulging...
    Just shooting some clairification to you, as you were not quite correct with your info.
    No harm / no foul.
  • pbjy May 11, 2010
    the power supply on the lrm-519 has 220uf at 200v, not 2200 uf at 10v.
    the main board has 3300uf not 2200uf.
Replace the capacitors located on the Secondary board they are C18 and C36 2200uf at 10v. You'll need a soldering iron and some solder and solder wick to remove to old solder. Purchase replacement capacitors, with the exact some specs as the original. Place to new ones in with the striped side of the capacitor facing the checkerd side printed on the board. Solder in place and snip of the excess wire from the capacitor on the back side of the PCB board. Put everything back together and it sould fire right up. This is a moderate fix, but some electronics knowledge is needed. Hopes this helps everybody.
Posted on Feb 12, 2009
  • 80 Answers
Change c18 and c36 both are 2200uf at 10v - they are on the power supply and most of the time they are green
Posted on Jun 12, 2008
The c18 capacitor did the trick for me. It was located on the power supply board. Everything works fine now. Jerry
Posted on Feb 11, 2009
Wat little black button on the mother board?
Posted on Jan 16, 2009
I will agree with the capacitor bulging being the main cause and also the fix.
As I do repair computers and have dealt with the same issue in many of a unnamed four letter manufacturer, In those years of 2004 -2006 many capacitors were cheaply made and bought from oversees and 80% of all of these unnamed manufacturer's motherboards had to be replaced due to "bulging capacitor failure". This failure takes time to show up.
Posted on Oct 25, 2008
I partially did what nipper00 posted by on Jun 12, 2008 by replacing c18 (2200uf at 10v). The red blinking LED now stayes solid and the system boots up completely. Will be stopping by Radioshack to get another one to replace c36.
Posted on Aug 31, 2008
Had the same thing happen to me as well. I unplugged power cord, removed cover, unplugged hard drive cables, and reassembled. Re-attached power cord and unit fire right up.
Posted on Jul 24, 2008
Same problem by power surge.
Many peole have same problem.
I believe this should be recall issue!
Posted on May 20, 2008
I have the same problem and will be taking it to a local service center tomorrow. I'll let everyone know what the problem was and how much it cost to repair. Ours is out of warranty so it will cost more but I should get it back faster. We shall see!
Posted on Apr 26, 2008
I'd like to know the answer to this one too. Mine has the exact same problem, also after a bad storm that caused the power to go out.
LG wouldn't give me a price quote at all... they said to just send it in and they would send an invoice. NOT!
Posted on Apr 24, 2008
Same problem, called LG and they said the hard drive died and no one will fix it but them. $69 fee just to look at it plus the cost of the parts. Not sure if it's worth it.
Posted on Apr 08, 2008
This is just wonderful. Mine has the same symptoms. We had a power surge last weekend, the DVR was hooked up to a Rayovac Surge protector. But I think someone left the DVR turned on during he outage, and it sufferd many on off events while power was being restored. I think it is probably a bad capacitor, but I'm no electrician.
Best Buy wants to send it to LG. Has anyone been this route? How much did they charge? I'm considering getting an HP with Microsoft program guide, and connecting it to my TV.
Posted on Mar 20, 2008
Sounds like a weak power supply
Posted on Dec 10, 2007
Posted on May 22, 2008
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
What lights indicate that the battery is charging and when the battery is full. Neither of the two batteries will charge and i have lost my receipt from argos
generally the red light indicates charging and the green one indicates full charge. If both flash at the same time it usually means the battery or the charger has a problem. Let me know if you need more assistance.
Apr 13, 2011 | Drills
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
I get a blinking yellow light when recharging my IRobot Roomba 550. What's wrong?
I am afraid you are having the problem of old or weak batteries. Old batteries at times tend to show such problems and do not show charge while charging properly. For this purpose, you can use a reliable Nicad Battery Repair Guide through which you can recharge the batteries without any problem and make them work like the new ones within no time, without anyone's help and you can do this all by sitting at home! I tried it and now I never buy new nicad batteries (http://www.nicadbatteryrepair.com/).
Jan 03, 2011 | iRobot Roomba 550 Vacuum
Nicad battery for makita want charge
For NiCd and NiMH batteries - check the battery voltage (for a good battery it is ~ 19, V); each battery contains 15 units 1.2 V each; you can test each unit after disassembling the battery case (my have 4 screws each, and the case has bottom and top parts). First charge the batteries; second, disassemble cases and check each unit voltage (shouldn't be less than 1.2 V); then take any battery tester (for AA, AAA and other batteries and accus for home usage), attach 2 long (~10 inches) wires to tester's testing contacts, and test each 1.2V unit for current - if it is in "yellow" or "red" zone - the unit is dead and needs replacement
Feb 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
18 volt ryobi batteries wont hold charge
NiCads stop taking a charge because microscopic crystals build between the individual battery cells (inside the pack) and the leads between them. here is what i have done for my craftsmen NiCad 18 volt batteries to get them to once again hold a charge:
you'll need ~2 to 3 times the voltage that you are using. for instance, if you've got a 14v drill battery that has stopped working, then you'll need 28-42 volts, 18v will need 36-54 volts. i have found 3 car (or motorcycle or lawn tractor) batteries work fine. so i have 2 motorcycle batteries and 1 tractor battery.
i hook these car/motorcycle/tractor batteries up in series. positive from one batt to the negative of the next and so on until i have one positive lead not connected and one negative lead not connected.
something like this: --(batt)+_--(batt)+_--(batt)+
then with safety glasses on i touch the positive lead from the motorcycle battery to the positive tab of the NiCad drill battery with one hand and the negative lead of the tractor battery to the negative tab of the NiCad drill battery (at the same time) and count to 3. i remove and wait a few seconds (5-7) and repeat 2 more times.
once the last ZAP is done, place the NiCad drill battery into the charger and see if the charge light illuminates. if it does, then you have just saved a battery from the land fill and some $$ from your pocket. if it doesn't, then try to repeat it once more, but no more after that.
some word of caution. do not let the the + & - leads of the car/motorcycle/tractor batteries touch each other. that's 36 volts you've got there and will spark/explode.
also, if during the zapping of the dead NiCad battery you hear a "pop", one NiCad cell inside the battery pack has given up the ghost and now the battery is trash for sure. take it to radio shack for recycling. do NOT attempt to zap it again.
use at least 14-16 guage wire (or larger which is a smaller number) to connect the batteries in series and also to zap the NiCad drill batteries.
one final note: do NOT use this method on Lithium Ion batteries. it will not work and may cause injury!!!
good luck.
Oct 20, 2008 | Drills
Temperature sensor
I have this clock and just finished getting it all working again. At first I kept messing around with the AAA batteries in the remote unit, finally realized there were AA batts in the back of the main clock/display unit. Replaced those, pressed the reset button next to the battery compartment. Pressed the reset button on the remote unit (it's under the back lid next to the AAA battery compartment). Little red light on the remote unit started flashing and remote temp showed on the main display. Then you have to wait for atomic time to reset itself or set the time and other display options manually - I kept messing around with the various buttons until I figured out how to do this (atomic time never reset) - start by holding down the smaller "AL" button on the top next to the big snooze/light button, use top two side buttons for up/down, use the AL button to go to next setting.
Aug 15, 2008 | Honeywell RC182WR Atomic Alarm Clock - Red
Lrm 519
Had same problem. My fix was to repair power supply.
On power supply board replace capictors C18 & C36.
2200mf 10v rated 105C
Dec 25, 2007 | LG Electronics LRM-519 Digital Media...
LG Electronics LRM-519 Digital Media Recorder Logo
798 people viewed this question
