Question about Sharp R-1480 Microwave Oven
Blow out Fuse
I already change the fuse from the supply line, but it keeps on blowing ones you plug the power
Thanks
Richard
  • Sharp Master
  • 9,098 Answers
Normally this would be a bad door switch, but it may also be a broken tab on the door switch mounts.
On that model, the fuse is located on the door switch mounts (called the door hook) so you've been there, and that's the area to focus on.
The hooklike projecitons on the door (called the latch heads) are held secure by the door hook so the switches are activated properly.
Sometimes a little tab breaks on the door hook which causes the switch to rotate out of place.
Other times, one or more switch will stick or short, and blow the fuse or breaker.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
You can find exploded view diagrams for this model here: http://www3.sears.com/ (3 is correct)
Here is some extra info for you:
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 06, 2007
Microwave keeps blowing fuse as soon as plug into wall receptacle.
Just to clarify: With the door closed, the fuse will blow as soon as you plug the unit in? Have you checked all three microswitches? One acts as a crowbar.
Dec 27, 2017 | Microwave Ovens
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
This model just stopped working while heating food up. Now cannot get even the power to register when you plug it in. Is this doen for?
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 4 in the parts listing (part number STD384200).
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Jul 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Do my microwave havea fuse because it wont turn
Yes, there is usually a 2 amp fuse located on the inside near the where the electrical cord feeds into the power supply. There might also be another fuse as well, be sure to check all around the power supply to be sure that there is only one fuse.
Plugging your microwave into an extension cord that is not rated for its use, or plugging the microwave into an un-grounded electrical socket could cause that fuse to blow.
I hope that this information was helpful to you in any way.
Apr 27, 2010 | Sharp R306L 1100 Watts Microwave Oven
My microwave XL1800 keeps blowing fuses
Now this is not quite clear enough to give an accurate single answer.
Is it the fuse within the microwave or the general house supply fuse that blows?
If its the latter then an electrician needs to create a separate fuse line to reduce the overall load on the fuse, 15amps generally. Many houses have too many plugs being used at once on the same circuit TV, dishwasher, fridge/freezer, electric jug etc all drawing power. Big screen Tv's are the worst offenders.
If it is the fuse within the Mwave, then it needs attention,as a short has developed in the unit and needs to be corrected.
I will assume it is less likely to be this and punt for the first solution ( House fuse box overload)
Please rate my help++++Thanks for using FIXYA
Feb 13, 2010 | GE XL1800 1100 Watts Microwave Oven
Fuse in microwave oven keeps blowing
does the fuse in the plug blow or the internal fuse if it blows the internal fuse it could be one of the door switches two of the switches have a red button on them and one has an orange button its normally the orange one thats at fault
Dec 28, 2009 | Panasonic NN-P295SF Microwave Oven
Microwave blows fuse when turn on
If it is blowing an internal fuse it could be a lot of things.
-short in the motor
-short in one of the other components
- gunk/dust could be causing a short
If it is your house circuit breaker/fuse then either the microwave draws too much current/amps for the circuit and you should try another circuit or you already have too many things/appliances plugged into the same circuit (not necessarily the same outlet) and need to unplug one or more of them so that the 'fuse' doesn't blow.
Kugellager
Nov 07, 2009 | Sharp R-1460 Microwave Oven
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
I have a J HP60G 002 GE Microwave (older)keeps
If it blows the line fuse instantly when you push start.... it is either a shorted HV capacitor or shorted monitor switch.... most likely.
Sep 13, 2009 | Microwave Ovens
No power at all. The outlet is fine. Is there an in-line fuse or reset button I can look for? Thanks.p
if you remove the case theres a 15 amp fuse in there , looks like the old automotive glass fuses but its not glass . it sometimes will blow for no reason , remove it and take it to any appliance parts place . you should have no problem .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 08, 2009 | GE JES1238 Microwave Oven
Sharp R-1480 Microwave Oven Logo
423 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
