Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Kenmore (253.51399104)side by side making buzzing/humming noise
Just replaced starter - pto called a compressor relay for my kenmore model 253.51399104 refrigerator. Prior to replacing, my freezer thawed, got no ice, kept hearing a humming/buzz then a click. Also, the compressor was warm. After replacing the compressor relay ($40.00), the initial startup buzzed/hummed but then the compressor did kick on shortly afterwards.
Q1: Should I still hear any buzz at startup; don't recall hearing it before.
Q2. Every blog I've read says "shake your old" relay and if it rattles then it's bad or fried. Well, the new relay rattled the same as the old. (identical looking to include the numbers). It's working now (except for the humm on startup); is the new relay faulty (part number 218721119). Is it common for some rattling of the starter ptc? Should it rattle at all?
Thanks aaron in DC
  • drumpeg Dec 06, 2007
    Thanks Catriver and Mike for the speedy response. Ofcouse I'm a little disappointed since I have the Tecumseh compressor. The new relay rattles the same as the old one. I will be contacting Sears to varify compressor warranty, but I know this refig was delivered in May 2002; so I maybe "sol." I'm getting ice and everything is working fine, but I do hear that litlle buzz, then she kicks on. If it goes down again, I will try the 3 n1 booster relay. Hope it last thru the New Year, and give me time to budget for a new one with the Embraco type compressor.
    My real issue is that this Tecumseh compressor was made in Brazil, while the relay was made in Mexico (probably part of NAFTA); love both countries but would love them more if their stuff held up half as long as my 20-yr old Kenmore in the basement that just will not break. The 20-yr old sold me on Kenmore; even so I know Kenmore is just a Sears label and not the main manufacture. So buying a Kenmore is like most of the NFL players: one year here; two years there; but back in the day you knew Roger Staubach and Terry Bradshaw were Cowboy and Steeler respectively; not these days.
    Thanks again fellows and Happy Holidays to you and your loved ones.
    aaron
  • 290 Answers
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Posted on Dec 06, 2007
    President:
  • 878 Answers
Aaron, I don't see too many relays go bad on this model but I do see the compressors fail. I would suspect your compressor windings are failing, therefore the buzzing. See how it goes after the refer runs a while. If you hear the buzzing and then a click, then it kicked out on the overload. If this refer is under 5 years old, that compressor is covered under the warranty....Catriver.
Kenmore model 596 52679200 compressor starter rattles.
It might be on the way out I would get the new relay and have it ready when the box fails. leave it be till it goes on out. But be ready. If it was bad it would either not do nothing or overheat and shut off.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 27, 2013 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Side-by-side Kenmore GSI23 making buzzing/ humming noise and not staying cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | Kenmore Refrigerators
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Bottom-Freezer Refrigerator humming/buzzing sound
HI, The nouse you are hearing is the relay on the compressor. It is possible the relay is going bad but, there is also a chance the conpressor is the problem. You should get a service amn to check it out. I would hate to se you change the relay and then the compressor ruin that too.
I hope tis helps.
Vic
May 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Noise & Clicking at regular intervals on working Kenmore 72214
yea that is the compressor relay, you will start to notice your food to thaw out and get bad. try to unplug for about an hour. if then it still does that call www.whirlpoolpartssurplus.com and get a relay kit.
May 06, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
Amana/Maytag ACD2234HRS sometime not working
If your compressor is running with the noise you described, I would make sure the parts that were replace on compressor are working properly. Also use a amp meter and get a reading on amp draw while it is humming. Anything that is above normal readings for the compressor would indicate compressor is bad or the relay and starter are not working properly. I need a series number also like a number 15 before the model number, Thanks, Sea Breeze
Mar 21, 2009 | Maytag MZD2766GES Side by Side...
Refrigerator humming noise and loss of coolness in freezer.
the relay overload on the compressor is bad. its a very common problem. replace the relay overload and it will start back up again. ( relay overload is what your calling the starter)
Nov 27, 2007 | Refrigerators
Kenmore not freezing nor cooling. humming noise
DONT SAY THAT COMPRESSORS BAD YET !!!! TECHCUMSE AND COPELAND ALL HAVE THE SAME COMPONENTS FOR STARTING THE COMPRESSOR. ALL COMPRESSORS HAVE EITHER A "PIN-TYPE PLUG-IN START RELAY, OR CAPACITOR START ASSIST RELAY" TO GET THE COMPESSOR TURNING.( FROST-FREE REFRIGERATORS ALMOST ALWAYS HAVE A START-CAPACITOR, RELAY, AND T-STAT COMBO ON ALL MAKES. THE IN LINE BI-METAL TYPE T-STAT THAT PREVENTS THE COMPRESSOR FRON OVER HEATING... THEY CAN GO WEAK. THIS IS THE "CLICKING SOUND YOU ARE HEARING !!! CALL A REPUTABLE DEALER THAT IS "FACTORY CERTIFIED" FOR YOUR MAKE AND MODEL AND GET A "FLAT-RATE" DIAGNOSTIC CHECK PERFORMED. NEVER LET A REPAIRMAN TAKE DEFECTIVE PARTS OUT OF YOUR HOUSE FOR ANY REASON. BY LAW THEY HAVE TO LET YOU KEEP THEM UNLESS THEY ARE REPLACING THEM COVERED UNDER WARRANTY FOR EXCHANGE. UNFORTUNATELY HUNDREDS OF CONSUMERS ARE "BILKED" BY THE " DOI-IT-ALL REPAIR-MAN. MOST MANUFACTURES ONLY HAVE 1 YEAR ON COMPRESSORS FOR REFRIGERATORS 5-10 YEARS ON A/C COMP. DONT BE AFFRAID TO WATCH AND ASK QUESTIONS TO REPAIRMEN YOU LET "INTO YOUR HOME".
Apr 27, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
1,363 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
