Question about HP OfficeJet 7140xi All-In-One InkJet Printer
Scanner failure While the printer sits there when not in use, the "scanner failure" appears in the screen and the light flashes. This happens when nothing is being sent to the printer or scanner.
  • 5 more comments
  • shopman9 Dec 06, 2007
    I have had the printer serviced just prior to this problem. The scanner works fine before the "scanner failure" message appears. If I turn it off and back on again the message goes away, but appears in a short time without using the scanner or the printer.
  • Anonymous Feb 08, 2008
    I have an all in one hp office jet 7100 series. The window on the unit keeps showing"scanner failure, turn power off then on again". When this appears nothing works (copier, fax, printer, nor scanner). After turning the unit off either by the on off button on the unit or unplugging it from the surge suppressor or the wall outlet and restarting it again everything works fine for 10 to 15 minutes
    after which the message reappears and I'm back where I started.
    Help, please
  • Anonymous Feb 20, 2008
    I have the HP Office Jet all in one and it shows the same Scanner Failure. I leave the house and it's fine and when I return I haven't recieved any faxes because it says scanner failure. What is the solution?
  • Anonymous Mar 03, 2008
    Same problem with HP 7110.
  • shopman9 Mar 14, 2008
    I HAD THIS PROBLEM BEFORE IT WENT IN FOR SERVICE FOR ANOTHER PROBLEM AND THIS.
    I WAS NOT PLEASED WITH THE SERVICE I RECEIVED FROM THE REPAIR SHOP AS THEY SAID THAT THEY WOULD TRY AND FIX THIS PROBLEM FOR AN ADDITIONAL FEE.
  • shopman9 Mar 15, 2008
    THIS DID NOT FIX THE PROBLEM
  • thomilee Jul 02, 2008
    scanner failure and i turn it off and on again but nothing change still scanner failure .what will i do?
    i cant even use the printer when its the scanner that has the problem
    Problem Solver:
  • 7 Answers
All over the web the concensus seems to be disassembly and cleaning bulb, mirros and/or the glass and a calibration strip. Mine has the same error, and I'm gonna try the cleaning those locations. This forum mentioned a disassembly procedure for the D145, I hope it's the same for the 7100 series (7140XI) I'll post back my success.
Posted on May 29, 2008
I have seen posts from other sites about this particular HP printer (d145 Officejet All in one). The only solution seems to be taking the unit apart to "clean" the inside glass surface for the scanner. I've looked at one and can't seem to find an easy way to open it up to perform the cleaning. Maybe someone has an old one they have experimented with. HP will NOT help with this or service it for that matter.
Posted on Nov 23, 2008
  • 56 Answers
Hi, It sounds to me that the scanner is bad or going bad. Have you tried turning of the unit and powering it back on to see if that makes a diffrence. If so more than likely your printer will need service. Hope this Helps!!!!!
Posted on Dec 06, 2007
  • WILLIAM MONDY
    WILLIAM MONDY Dec 06, 2007
    Hi, If you had the printer serviced just prior to this I would be calling the service company you used and explain to them the problem your having. I wished I could help more but I don't know what the initial tech did or replaced when they were troubleshooting the problem.
Have a brand new printer not used till now, cyan/magenta printhead light and the light for the power bottom both flashes, and a message appears (printhead problem - the following printhead has a problem...
this sounds simular to the photosmart C7250 ink system failure. which cause by air in the lines. and we fix this by reseting the printer and it redoes the cartridge installation. thus pushing all the air out.
Dec 24, 2010 | HP OfficeJet Pro K8600 Printer
Scanner doesn't work
This is a HARDWARE FAILURE with the OCR optical charactor recon, sensor ot lamp.
If the lamp comes on then goes off this will need to be repaired. This is a hardware issue not software.
thanks and please do be considerate when passing threw fixya.com today to leave postive feedback and ratings to those who have tried to help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 27, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP 7410 will not boot. It powers up and the HP logo screen flashe
This was solved really well on this blog. It is some problem with the wifi board. If you disconnect it (no so hard and well explained on the blog) you will have network printing over a cable but no wireless.
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
Oct 23, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I keep getting a scanner failure when I try to fax something from my all in one Officejet k60.
i can understand the situation here is the soluition for you :
1.TRY TO MAKE A COPY
2.if the copy does not happen open the scanner glass and check whether the scanner lamp that is tdo you see any light in the glass glowing or moving
3.if nothing gloes or move then i am sorry to say that you will only be able to print from the printer and nothing else
4.if the printer is in warranty call hp they replace it for you .............................. thank you and hope you do see the scanner lamp
Oct 20, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
How to start a scan? when i press the scan button,the power light flashes green,but nothing happeneds?
If u find this kind of prob then u have scan the required stuff by using ur scanner software if u r using hp then go for controlpanel click on scanner and camera devices and follow the on screen instructions to scan the required one hope this will solve ur prob.
Jul 07, 2009 | HP Ruggedized DC Car Adapter for HP...
In pop up window it tells me colour cartridge error remove and check which i have done to no avail. also on comp screen tells me cart error. Have tried to press set up nothing happens. Also have a red...
Make sure the cartiages are sitting tightly in the printer and isn't loose. There are contacts on the cartiages and if the contacts aren't touching the ones properly in the printer it will show that cartiages aren't there.
Aug 21, 2008 | HP Office Equipment & Supplies
HP OfficeJet 7140xi All-In-One InkJet Printer Logo
860 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
