Question about Samsung SyncMaster 913V 19" LCD Monitor
Lcd flat panel
I tossed a CD up onto my desk and it hit my lcd computer monitor. It not has lines running in different directions where the CD hit it. Is this repairable?
  • William620 Dec 06, 2007
    It now has lines running in different directions where the CD hit it. Is this repairable?
  • 121 Answers
I'm sorry, but it sounds like you have a damaged LCD panel, and that can't be repaired. Check carefully to see if it's just the outer plastic that has cracks, but if the lines seem to be "electronic" colored lines you're probably out of luck.
Posted on Dec 06, 2007
Vertical red lines no matter what input.
I'm assuming you're dealing with an LCD flat panel monitor.
If you've tried different input and from different computers and different cables, and you're still seeing vertical red lines, it's highly likely that the LCD is failing and there's not much that can be done easily to fix it. You will probably need to replace the LCD panel.
If the red lines are in different locations each time you power on, then it could be a controller board issue. But, if the lines are always in the same place, it's probably the LCD panel itself.
Oct 22, 2016 | Computers & Internet
I have had a 52" LG TV for about 17 months. I connect several devices (XBOX,CABLE,PC) through a receiver to the TV via HDMI. it worked fine all the time but now all of a sudden all I am getting is a no...
Did you change the HDMI cable? If so, you should check to ensure you have the cable installed so it is running the right direction. It may seem hard to believe but some HDMI cables only allow the signal to run in one direction.
Aug 05, 2014 | LG M5203CCBA 52-inch LCD Flat Panel...
Dell 1504FP hdmi
It doesnt matter how many different ways you connct the monitor it will only support one input at a time
May 12, 2014 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
Liquidvideo desk top L17LCD2 turns on and off.
Yes! I think you would be further ahead getting a brand new monitor since they have come down in price.
Jun 24, 2012 | Liquid Video L17LCD2 17" Flat Panel LCD...
The picture is scramble
I see the pictures, you need new screen, the LCD panel is cracked, sorry for the bad news! The screen will cost more tahn the new monitor.
Jun 07, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
My HP vs 17 LCD monitor is stuck to my desk.
spilled coffee or cola on the the desk
soak it in water, with 1 drop dish soap.
let is side there, even lay down paper towels soaked.
then in 15 to 30min, it will un glue.
this is not a PC question, or electronics
pure mechanics.
even ash tray or vase can do that, if sugar drinks spilled.
Oct 27, 2017 | HP Vs17 17" LCD Flat Panel Monitor
Screen on my monitor is turned
Use the CTRL-ALT-ARROW combination to flip the screen around. This is a problem that occurs when someone goes to press ctrl-alt-del and hits an arrow by mistake and does not realize it. I work the help desk in the I.T. department at a major hospital in south Alabama and several of the users have had this problem with Windows XP. You may have to try different arrows until you get the screen turned right side up.
Oct 09, 2008 | Samsung SyncMaster 712N 17" Flat Panel LCD...
I was tring to Connect Two Computers to One Monitor, but i didnt get it, does someone know how to do so? I bought a KVM switch, USB to use between a new Acer running Win XP and old Dell with Win 98. Could...
I guessing that since **-one responded you've given up and returned the whole mess but what the hey.
A lot depends on the KVM you're using. There are some high end units that will match different sources to the monitor but most work best with matched input and output. Unless you's specifically states that it will convert analog to digital it won't. So if it's an analog KVM then both the computer video boards need to have an analog VGA jack and the monitor does too. If the KVM is ditital you need to have all the systems and monitor digital. Savi? The Monitor may support boath analog and digital input but NOT at the same time. You can't plug in two computers at the same time, that's what the KVM is for.
The bottom line here is that you typically need to run the least common de**minator to use a KVM. Also, if the computers have different frequency (resolution) out put and you hit the KVM switch then the monitor will freak out. Some monitors will auto-switch between frequencies but most don't (especially the cheapies).
There are adapters that will down convert digital to analog. If you're dead set on using the KVM with that old Dell then you may need to plug the down converter into the Acer Video Board but you'll loose the high resolution and sharp picture from the digital video. If it was me and I had to use the KVM, I'd get a cheap digital video card for the Dell or just run two monitors.
I run 5 systems on my desk, Three of which are older servers with analog video. They share an analog KVM with video and keyboard on the wall. The other two systems are current generation and share a KVM and 27" flat panel center desk. I also have a laptop that hangs on the other wall with a laser blue tooth keyboard on the other side of my desk. Now if my wife would only let me turn part of her craft studio into a server room.....
Feb 14, 2008 | AOC 19LVWK LCD Monitor
Gateway FPD 1730 17 in. Flat... Problem
Try using it on a different computer, it's possible that it is your graphics card causing the problem. Check for bent pins.
Dec 20, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Samsung SyncMaster 913V 19" LCD Monitor Logo
98 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
