Question about Roper RAX4232KQ Top Load Washer
Will not start
My washer stopped in the wash cycle. will not start in any cycle. I hear a faint buzz when knob is turned on, but nothing happens. how can i release the water? what do you think is the problem?
    President:
  • 878 Answers
Bsolo, sounds like something jammed in your pump stopping the motor. You will have to remove the cabinet to get at the pump. It has 2 clips that hold it to the motor. The best way to tell for sure is to remove the cabinet, jump the lid switch and start the washer. If the motor runs without the pump, then you know for sure it's jammed. I will try to attach a diagram on how to remove the cabinet.will not start - 6212c10.gif
Posted on Dec 06, 2007
Fridgeaire washer dryer stack unit. The washer side doesn't complete cycle.
check door lock switch if not water valve for cold side is not on or valve is defective buzzing sound from water valve means not opening
Jun 27, 2016 | Frigidaire Washing Machines
My washer went through the wash cycle and into the rinse cycle and just stopped at the drain/spin part. When I pull the knob on there is a buzzing noise for about 10 to 15 seconds and then nothing. I...
I would call a local appliance store that sells and does repairs. Explain what's happening. They will probably be able to tell you if it needs service, and what type of problem it has.
Feb 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Front load kenmore washer model 417 will not enter any wash cycle. It will do the rinse and spin cycle but not a wash
will it fill with water? if not listen by the water hose when you press start to wash and see if you hear a faint buzz/humming sound. If so you need to replace the water inlet valve. cheers
Mar 25, 2009 | Washing Machines
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Roper RAX4232KQ Top Load Washer Logo
54 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
