Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Vertical lines on screen
We have a Pioneer SD-533HD5 big screen T.V. The screen has two vertical lines on the screen and a small multi color line half way across the bottom of the screen? Any suggestions or solutions?
    President:
  • 4,402 Answers
This is the convergence gone bad. that is what was blowing the fuse. this is the board on the far left. there are two stk`s on this board. stk392-110.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 06, 2007
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer PDP-4300 43" Plasma TV, 1/8 of screen has vertical stripes no picture
Look to see PIP or picture in picture is not engaged as it may be doing this.
Dec 10, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Color is out of balance on bottom half of screen
This tv have covergence problems,it dead.The convergence board the 2 STK covergence ICS and some or all it resistors are dead.Must replaced these parts to solved convergence problems.The shop will cost u $300-350 for parts and labors.
May 23, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
I have a pioneersd-533hd5 there is a purple shadow under display letters and sems out of focus
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 27, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Greenish color when using component to RGB connection
either the problem of convergence ICS or the problem of convergence settings.
for replacement of ics click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
for the settings click this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Aug 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5 convergance
for pictures on where is the convergence settings click on this given link.
but if its the problem in convergence board then check out for this link
thanks.
May 08, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Need to find out how to adjust color
im curious why you think you need to ajust the color do you have red screen? or missaligned colors?
If your B&W images look okay (bright and dark areas), either films, ads,
or turing the color off, you shouldn't tinker with grayscale
adjustments. You'll really mess up your set. Haven't seen many
complaints about 'red push' with Pioneers, but that may be the problem.
A further check would be the decoder test on the Avia disc. Also visit
http://www.hometheaterspot.com/ and search the Pioneer section for
similar complaints.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
198 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
