Question about Car Audio & Video
Wiring diagram for car radio
Free download for 95' nissan maxima 4dr sdn wiring diagram for radio
  • Anonymous Feb 06, 2009
    volteje imvertido
WHERE DO I CONNECT THE PINK WIRE IN THE JENSEN VM9311TS AM/FM/DVD/MP3 RECEIVER
Posted on Apr 14, 2009
Where is conect orange wire in kenwood kdc-128
Posted on Dec 11, 2008
Want to use removed 95 Nissan Maxima's radio unit and 2 rear speakers as a stand-alone system at home. How to apply +12 V to the radio unit and speakers? Which wires (out of plenty of them exposed) sh
red is normally power in and black is normally earth wire. Get a 12 volt dc transformer that plugs into the power outlet and get the plug jack socket from a electronic shop and solder the wires correctly (red to centre pole ) and it should work . You will need a high wattage transformer for this.
Nov 12, 2013 | 1995 Nissan Maxima
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
I need wiring diagram from factory radio bougt car at sale old radio removed putting in pioneer stero on 1993 nissian maxima
1993 Nissan Maxima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/Black
Radio Illumination Wire: Red/Yellow
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Rear Speakers Size: 6′ x 9′
pls rate because noone has been rating hope this helps
Jul 10, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
I have a 95 nissan maxima and the emission light came on. What do I need to do or check for.
You need to get a dianogstic code reading which can be done at autozone for free on if the light light is on.
May 19, 2010 | 1995 Nissan Maxima
My surpentine belt on my 95 nissan maxima i need a diagram
HI. I have posted the requested information below.
Mar 01, 2010 | 1995 Nissan Maxima
Radio wiring diagram and car stereo wire diagram 1992 nissan maxima
what color wires would the constant illumination and switched be on a 1992 nissan maxima gxe
Sep 20, 2009 | 1992 Nissan Maxima
How do i REMOVE AND REPLACE THE ALTERNATOR ON MY 95 NISSAN MAXIMA?
TURN OFF RADIO TO KEEP FROM LOSING RADIO CODE.THEN YOU REMOVE NEGATIVE BATTERY CABLE.DISCONNECT THE 2 LEAD WIRES AND HARNESS CONECTOR FROM ALTERNATOR LOOSEN THE DRIVE BELT ADJUSTING BOLT AND REMOVE THE BELT. UNSCREW THE ALTERNATOR ATTACHING BOLTS AND REMOVE THE ALTERNATOR FROM VECHICLE.VISA VERSA PUT EVERY THING BACK.AND ADJUST ALTERNATOR BELT TENSION.WARNING DONT PUT TOO MUCH TENSION ON BELT.BECAUSE YOU WILL DAMAGE ALTERNATOR PULLEY BEARING.
Aug 01, 2009 | 1995 Nissan Maxima
Car Audio & Video Logo
1,479 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
