Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest setting and the refrigerator part is set at 7 its highest setting. The items in my fridge seem to be just cool enough. The freezer is a bottom drawer. Please help the refrigerator is only 2 yrs old and it has always been this way. The warranty has expired.
  • 1 more comment
  • firehoose Apr 05, 2008
  • PKSLINK Jul 22, 2008
    mY REFRIGERATOR WAS WORKING FINE, THEN I LAYED IT IN THE BACK OF MY TRUCK AND MOVED TO ANOTHER LOCATION. I LET IT SIT OVERNIGHT (12 HRS) AND PLUGGED IT IN, NOW IT DOES NOT GET COOL.
    PKSLINK@AOL.COM
  • Anonymous Mar 31, 2014
    Freezer or refrigerator not cooling.
  • 828 Answers
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Posted on May 03, 2008
My LG LRFC22750 shows an error code ER FF and my refrigerator is getting warmer while my freezer is still cold. What should I do to fix it.
The FF error means that the freezer fan isn't working properly. The motor may have malfunctioned or ice has built up and is preventing the fan from turning. Unplug the refrigerator, remove the food to other cold storage locations (cooler, another fridge) and allow it to defrost. Dry up any moisture around the unit. Plug it back in and allow it to cool for 4 hours. If the error returns, the refrigeratr needs service.
Generally, you need to replace the fan motor and the motherboard in the refrigerator. (The motor keeps trying to spin until it becomes damaged, even if the problem was ice build up.) The fan pushes the air into the refrigerator to keep it cool. The freezer is more directly cooled by the refrigerant cycling through the unit. If your refrigerator is still under warranty, contact LG. (There is a 1 year warranty on most of the unit. The sealed refrigerant system has a 7 year warranty on those parts.)
I hope this helps.
(Unfortunately, I do not have a source for parts.)
Mar 26, 2015 | LG 22 Cu. Ft. French Door Refrigerator,...
Beko fan noisey
It can be worn out or dusty fan motor, or its time to replace fan motor.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Fan turns off in refrigerator section.
Its issue with defrost timer causing the fan to turn OFF.
Get the timer checked.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Freezer fan not running
It can be faulty fan motor or blown compressor capacitor.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Fan has failed on out side unit, It may also need new capacitors.
Its available at sears parts store.
The fan motor may be for $50 and capacitor for $10 to 15
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Suddenly started making a high pitched screeming noise on the freezer side
Ice has built up and is hitting the fan... or the fan bearings have gone bad... Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 07, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer and Refrigerator are not getting cool enough
there is more ice built up behind the panel
defrost is not working
Jun 27, 2009 | LG 26 Cu. Ft. Side By Side Refrigerator...
Hotpiont side/side HSS251FMB not cooling
Compressor might be working but you may have lost some freon. Continued operation with low freon can lead to other problems. This may require a service call since recharging freon can only be done by a service professional.
Apr 30, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator.
If you have determined that the evaporator fan in back of the freezer compartment is running, then you might have a stuck or broken air diffuser. The diffuser acts like a damper to divert air into the refrigerator compartment. Sometimes they jam or break due to frost buildup.
Jul 23, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
387 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
