Question about RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3
My screen is dark and wont lit up, i cant see a thing
  • 1 more comment
  • Anonymous Dec 09, 2007
    screen is went out
  • meyasee Jan 06, 2008
    i can see a small box at the top of the screen the rest is dark
  • KeLsEy69 Jun 29, 2008
    my screen is set to as bright as it goes but i can bearly see it even in the dark
  • 8,596 Answers
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
  1. Right click on the device within the Explorer or My Computer window
  2. Select the format command (full format) to reformat the internal memory of the device.
  3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Posted on Jun 18, 2008
Why is my heated auto dimming driver side and rear view mirror getting dark when driving
Look in the fuse box for the fuse it will likely have other things on it but nothing to high voltage .
Pull the fuse and see what happens .
Honestly I have never heard of this .
Unless the mirrors lit or damaged somehow from to much heat damaging the coating on the back of the glass making it not a mirror any more .
This sounds like a factory defect
Feb 19, 2016 | 2004 Chevrolet Avalanche
Philips 50PF9956 50" Black Levels
Did you try backing down the contrast?...about the only thing I can think of would be issues with the main board if its not an adjustment in the picture settings in menu
Nov 23, 2017 | Philips 50PF9956 50 in. HD-Ready Plasma...
Screen is just lit up blank cant turn off or get
were you trying to unlock or jailbreak it ? be that as it may remove the battery for about 10 minutes and then try and turn on the phone again. should work unless the error occured while you were doing either of those two things
Oct 21, 2009 | Apple iPod touch
Itouch dark screen, won't go to homepage, can't charge.
facebook screen dark and it wont let me log on cant enter my username or password. What could be wrong?
Sep 13, 2009 | Apple iPod touch
Swith on the cell phone it is lit up and the screen is blank cant see a thing
Sound like the display is going up or poor contacts on it. Try applying pressure to it by squeezing the phone firmly and try twisting it at the same time (not too hard, you don't wont to break it in half). Does the keypad still light up? If so this is most likely a display issue and the phone will need to be replaced (repair may be possible if your carrier has a Tech repair department). Phone repair is not for the faint of heart, there are a lot of really small parts in there! If you cant get it fixed I suggest upgrading if your contract is almost up or eBay (if you have a SIM type phone). That's why I love the SIM; I am not tied to one handset
May 17, 2009 | Sony Ericsson Z520a Cellular Phone
Nokia 6126 Screen problem
i have to say, the same thing happened to both of my nokia 6126's.
Jun 04, 2008 | Nokia 6126 Cellular Phone
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Screen to dark to read
Find out if you are still in warranty this is not fixable.
Mar 01, 2008 | RCA OPAL M4001 MP3 Player
Kyocera - Strobe
Open your phone to the qwerty keypad. In the righthand corner above and between the speaker and power/clear buttons, there should be a whiteish little button. Is anything obstructing it? Try pressing it gently a few times with a small phillips screwdriver or a ball-point pen top. GENTLY being the keyword! When you push that down, your outer screen should be lit up, and when you release it, it should light up the inside screen. Note that when your inside screen is lit, that your outer screen should light up blue-black-purple, and vice-versa.
If there is no obstruction that can be easily removed or fixed, I reccomend returning it to the retailer/company for a refund or new phone.
As a strobe owner, I understand your frustration. Worst phone I've had so far.
Sep 29, 2007 | Kyocera Switchback KX21 Cellular Phone
RCA OPAL M4001 MP3 Player Logo
61 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
