Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Icemaker Not working
My Icemaker on my fridge is not working I just got this fridge from a secondhand place. When I hold down the Door Close button the red light goes off. I have had it on for like a day and no ice does this just take awhile or is it broken?
  • bonbebe Dec 06, 2007
    how do i fix the light problem?
  • 100 Answers
No it should take about 24 hrs to get a full bin of ice. The most common problems with this style icemaker is the fill tube freezes which they have a replacement heated fill tube or the board on your freezer wall that pass a light through your ice bin to tell if its full or not stops working
Posted on Dec 05, 2007
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
My kenmore fridge - 4 years old - has developed an intermittant rattle. Stops when the door is open on fridge or freezer. Starts again if you open the door but hold down the light button so it...
That button just turns the interior light on when you open the door and off when you close it. Could a light bulb be slightly unscrewed? Or perhaps the bulb cover is loose?
Dec 27, 2010 | Refrigerators
Icemaker makes ice, but will not dispense ice via door.
The auger arm in the back of the freezer should be rotating to test this hold the door switch in and push the dispise button down. If it does not even try it could be the control switch on the door. the auger motor is a 120v motor and relatively strong. You can test to see if you can manually turn the arm it should trurn stiffly. Its alsoi a chance you don't have the been in place correctly.
Jan 10, 2010 | Frigidaire FRS23R4A Side by Side...
I'm looking for instructions on how to program the keyless remote
HOLD TO UNLOCK BUTTON ON YOUR DRIVERS DOOR, WHILE HOLDING BUTTON DOWN TURN KEY ON, OFF, ON OFF, ON OFF, YOUR DOOR LOCKS SHOULD CYCLE,. LET GO OF THE UNLOCK BUTTON. HOLD DOWN LOCK AND UNLOCK BUTTONS ON YOUR REMOTE AT THE SAME. IT WILL TAKE ABOUT 1 MIN AND YOUR DOOR LOCKS WILL CYCLE AGAIN. IF YOU HAVE MORE THAN ONE REMOTE, HOLD DOWN LOCK AND UNLOCK ON THAT REMOTE AFTER FIRST REMOTE IS PROGRAMMED. ONE AT A TIME. TURN VEHICLE ON AND TURN BACK OFF. YOUR REMOTES SHOULD WORK. GOOD PLACE TO HOLD YOUR REMOTES IS CLOSE TO IGN. CYLINDER SWITCH
May 04, 2009 | 1995 GMC Jimmy
Garrage door opener ability to close the garrage door
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
We accidently left the freezer door open during the entire night and now icemaker doesn't dispense on monogram refrigerator, even though ice maker makes ice.
you might want to turn the whole fridge off (remove the food to a safe place) and let the fridge defrost, wipe any water up and retry. If it is under warranty, call GE
Nov 26, 2008 | GE Monogram ZDI15C Automatic Icemaker
Fridge not cold
I think that I have a solution. Refridgerator side not cooling.
I read in the blogs that holding down the top two bottons(power cool & fridge) at the same time resets the refridgerator control panel.
I may have caused the problem by leaving the door open. If my above solution does not work, then I will defrost the frefrigerator just in case the coils are froze up. It works with my air conditioner.
Ed
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag ice20
When replaceing the highvoltage control board be careful to not handle it too much as nano voltages can burn it. Unplug before repair. Simply hook it up the way you unhooked it very easy and in the left back of the fridge. Now that it's installed plug fridge in and push back to wall. Look at model tag and write down your code something like 0304 most likely. Go to digital control hold down door alarm and freezer - minus button for 3sec. then let off door alarm now you should see PE flashing the fridge wants personality code (the one you have wrote down). Let off minus now it should show 0000 now push minus once more a decimal should show up 0.000 the decimal indicates what number your about to change. Move the decimal with freezer plus button and lower or higher number setting with fridge side buttons.Once your done hold down freezer minus till the numbers are flashing then open any door and close. Now the fridge should be working properly.Hope I helped
Dec 12, 2007 | Maytag MFD2560HES Bottom Freezer French...
Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Apr 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
101 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
