Kenmore top load (model # 110 82370120) drain problem
Machine switches to drain after filling and in the washing cycle. All the water drains out which washing and it fills again over and over. What part do I need?
washing machine stops mid cycle with soapy water
  • 240 Answers
Good AM. I see here that you have a fairly old belt drive Kenmore washer. The real problem with these is that the parts for them are so very expensive anymore to get. A timer (which you may be needing) will run you around $100.00 to $175.00 depending on where you live. Very expensive repairs on these, but if you want to go for it, here are some hints to help. Sounds like you have one of three problems. First off PLEASE UNPLUG YOUR MACHINE BEFORE WORKING ON IT. Your timer may have lost or has a stuck contact inside (unrepairable in most cases) which is making it do something is shouldnt be doing in that area of the timer. This would probably be the most expensive of your repair. The next thing is it could be the water level switch could be going bad. This one is highly doubtful since it fills and stops filling, but I have heard (but never have seen) that they can short out sometimes and cause wacky operation. Both these issues can be fixed by remove the console rear panel and front knobs to remove both. The next item could be a defective wig-wag in the bottom of the unit. One of the positioning solinoids maybe going bad and sending bad signals back to the timer.
None of these problems are really hard to fix. And truthfully (even though some of these guys will be mad) you can sometimes find these parts on ebay for a halfway good price. Part numbers for each are:
Timer: 381860
Water Level Switch: 359712
Wig-Wag: 89814
Good luck with this one, and if you know how to use one, try to run resistance with an ohm-meter on your wig-wag to be sure your getting power flow through the soilnoids (you will have 2, be sure to unplug the solinoids before testing to be sure its a true test) before replacing.
Posted on Dec 06, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
We had a similar-sounding problem that was due to a worn-out water pump (impeller).
The pump itself was not worn out, but built into the pump is a valve that prevents water from pumping out the drain hose when it is not supposed to.
Replacing the water pump solved the problem.
The water pump runs all the time the motor runs whether the washer is agitating, draining or spinning. So, if the valve does not close all the way or the rubber washer on the valve is worn out or broken the water drains all the time, although at a slower rate than when it is actually draining. When the water level drops below a certain point, the machine fills up again. This repeats until the timer actually reaches "drain." Then drain and spin worked normally. In the rinse cycle the fill-drain-refill repeated just like in the wash cycle
Posted on Apr 03, 2010
How do I find the lid sensor switch on a Kenmore 500 washing machine
If the washing machine stops in the middle of the cycle then it is very unlikely the lid switch is involved. It could be a number of reasons.
Best to drain the washing machine and repeat the cycle a few times to check if it happens at the same point. Could be a problem with the timer or pressure switch.
You can locate all the parts and their location in this site. I hope I have the correct model for your washing machine.
KENMORE Residential Washer Parts Model 11029522800
Aug 05, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Could you please rephrase the question. I'm not sure if I'm understanding this correctly
Dec 01, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
306 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
