Monitors
Problem for Monitors
Generic problem for all Monitors
Dell LCD Monitor
By Ryno062867 on Dec 05, 2007
Trying to install a Dell monitor with my existing Compaq pc. I can get it to power up, but right before my desktop displays the screen goes blank then I get an "Out of Range" error. Can you help?
Comments:
Feb 08, 2008
- No Help...
Same Problem
May 27, 2008
-   I have not changed my monitor or settings with the x2 gen 19". The out of range message came up and my screen is black. Now I can't access my computer because I do not have another monitor. Is this just a matter of changing the resolution of the monitor-   stp3489
Feb 05, 2008
-   try to power up & screen says out of range.-   Kevaug14
Solution #1
posted on Feb 05, 2008
Not Helpful)
Kevaug14
Rank: Apprentice
Rating: 40%, 1 votes
out of range
Was this helpful?
Yes
No
Solution #2
posted on Apr 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
maybe your new monitor cant handle the resolution settings your old monitor was using, try installing your old monitor, or one you know can use the setting you have defaulted, then lower the resolution, and then try the new one again, or boot the new one in safe mode, hope this helps
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
beeping when i turn on?
Answer
It seem as though the green back drop bleeding through. I ajusted the sreen resolution and the... (More)
Answer
monitor turns on at startup, then goes black and stays that way. All wires are plugged in properly
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
