Question about Fargo DTC525 ID Card Printer
Breaking since I change printhead
My DTC525 printer is continuosly breaking the ribbon since I change the printhead
If your TOF value is too great then this will also result in the ribbon being broken. Try reducing this value.
Posted on Sep 23, 2008
    Sniper:
  • 56 Answers
Hi, i think you must to adjust tension of ribbon.Go to menu and find adjustmento for tension,and try to adjust to "-" or "+" value, in small increaments.Print card and if no results,try again.
BR
Posted on Feb 01, 2008
Why do I have a white line across the cards?
most likely, your printhead has a damaged pixel on that portion of the printhead. it would need to be replaced. If you need a printhead, i can get you a couple companies including myself.
thanks
Aug 30, 2014 | Fargo DTC525 ID Card Printer
Dtc525 printhead not printing. no error
1, how do you know is the print head that is not doing the job
2, did you check if the print head is slack or a it lose ?
Apr 06, 2014 | Fargo DTC525 ID Card Printer
Which tipe of ribbon to be used in DTC525
hello
http://www.idsuperstore.com/fargo-printer-ribbons-fargo-dtc525lc-ribbons-c-5_79_1472.html
try this link for your ribbon printers
thanks
Mar 03, 2011 | Fargo DTC525 ID Card Printer
Ribbion keeps breaking
locate the tension ribbon and - it
Dec 03, 2010 | Fargo DTC525 ID Card Printer
I have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Jul 08, 2009 | Zebra Z6M Plus Thermal Label Printer
DataCard printer ribbon breaks
First, what color is it breaking on? Yellow, Magenta, Cyan, Black, Topcoat?
Next, I would do is clean all the rollers in the printer with isoprophyl alcohol (99% if you can find it, 91% is ok, 75% is you're in a bind). This is a common problem
Then, load the Printer Diagnostics from your print driver CD. In diagnostics, you can set the BASE POWER for YMC, K or Topcoat. The base power is totally different from intensity. As the printhead gets old, you may need to back off the intensity to keep the ribbon from breaking.
Lastly, take a look at the ribbon:
Is the image placed in the same spot of the ribbon on each panel or does it move (creep) higher or lower? This creeping action is caused by many things and would be best to be serviced by a technician.
Finally, printhead replacement. About $695 MSRP
May 26, 2009 | Datacard Group ImageCard Platinum Printer
Ribbon keeps breaking
It might be because the printhead is heating up too high, and burning the ribbon.
Try lowering the heat in the driver.
Dec 31, 2008 | Fargo Persona C11 Thermal Printer
Is there a fargo certified service center in the Seattle or surrounding areas?
You could look at Fargo website www.fargo.com to find service center neer you or call customer service they will help you Number on website
Aug 06, 2008 | Fargo DTC525 ID Card Printer
Ribbon Breakage
You can try to lower printhead setting values (color and black), if not resolved then try another ribbon, old ones trend to fail this way.
Regards
Jul 10, 2008 | Zebra Eltron P310I Thermal Card Printer
Breaking Ribbon
Ribbon breaking continuously is caused by 2 common problems. 1. The printhead is going down before OR after the card has passed through. You would know this when you open your cover, and unlock you printhead, is the break before or after the card? Try printing the test page from the driver. That doesn't print "Edge to Edge" so if this is the problem, it should not break. 2. The print head heat settings are too high. If this is so, you can change this on the printers menu panel. I can explain more information, once I know your problem.
Jan 15, 2007 | Fargo DTC525 ID Card Printer
Fargo DTC525 ID Card Printer Logo
352 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
