Tv is messed up
After playing for few minutes picture starts closing in from bottom, then it closes all the way with blue green and red lines bowed in wierd way
    President:
  • 4,402 Answers
Need manufacture and model#
most likely convergence chips going
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 06, 2007
Changed ICs Chips but still got bad convergence
After the IC replacement, convergence adjustments should be done. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Details of this adjustments are given.
May 01, 2017 | Philips 60PP9202 60" Rear Projection...
Blue red green lines around people images
this is caused by some kind of electrical interference. this can be caused by cd players,speakers, etc being too close to the tube. after you find the culprit and remove or move, unplug tv for about 10 mins, then plug back in
Sep 06, 2009 | RCA F32649 32" TV
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Green convergance wont adjust, bowed screen
Green really shouldn't be adjusted, you adjust red and blue to the green. When a color is bowed that indicates that a part or two are bad, probably the convergence output IC's and possibly a fuse or fusible resister. You may need a tech to come adjust it for you because after replacing IC's the adjustments should be done in the servicers menus not just in the consumers menus.
Mar 13, 2009 | RCA P52937 52" Rear Projection Television
Picture problems
check for cold solder joints around the flyback transformer and a open pico type fuse very close to it. they are rectangle in shape and ususually the one in the middle of the three is the culprit. The problem is in the pincushion circuit
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Convergence issue with blue
You need to replace the convergence Ics located up front behind the speaker grille numbers STK392-110 you can get replacements at the following link and they provide free tech support and instalation instructions with pictures. heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | JVC AV-56WP74 56" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Aug 16, 2007 | Zenith R56W36 56" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
