Toshiba 36A40 36" TV
Problem for Toshiba 36A40 36" TV
MY SCREEN SHOWS ONLY A BRIGHT LINE STRAIT ACROSS
By alnanpreston on Aug 29, 2009
MY SCREEN SHOWS ONLY A BRIGHT LINE STRAIT ACROSS THE CENTER OF THE SCREEN
Best Solution
posted on Aug 29, 2009
Very Helpful)
dmftrucker
Rank: Guru
Rating: 87%, 412 votes
you more than likely have a coupling capacitor defective in the vertical driver/output circuitry,or you can have "COLD"solder joints in these or the power supply section,carefully tap in every area on the case,if picture starts to expand and collapse, then its a solder joint thats bad/if you can take back cover off take an insulated plastic instrument and tap and push on board and components to see if you get the same results...be careful inside case
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Toshiba 36A40 36" TV
Questions and Unsolved Problems for Toshiba 36A40 36" TV
Do you recommend Toshiba 36A40 36" TV?
Answer
Answer
i lost the paper work to program my remote
Answer
i can't program my remote for the tv
Answer
tv turns on then goes to flickering and lines appear
Answer
My Toshiba tv keeps blinking Toshiba entertainment system across the screen and it wont let me use... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 36A40 36" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
