Question about Refrigerators
Magic chef refrigerator relay/overload
New relay looks different from old there is no place to tie in capisitor there is a white wire called a jumper wire instuctions are crazy
  • 100 Answers
SOURCE: magic chef refrigerator relay/overload
You need at least two terminals on your relay to hook up a capacitor, one wire of the capacitor goes on one terminal of the relay and the other capacitor wire would get spliced in with the neutral line that plugs into the relay
Posted on Dec 05, 2007
0 characters
1 Points
Part 2 when it tries to start i hear a click coming from the overload-start capacitor side of compressor. fan is working.
check the capacitor overload protector and starting relay if they are all good, if one of them is found not functioning replace it. with new accessory installed , plug in the unit. if still you hear a click and compressor don't start , replace it . before you start anything on the unit be sure you know what you're doing. if in doubt call the experts.thanks,
Mar 02, 2016 | Magic Chef Refrigerator. 10.0 cu. ft....
Dec 05, 2007 | Refrigerators
Just over a year old - quit running. From schematic on back, it has an overload reset but having trouble finding it. When plugged in, do however hear a slight hum. lar
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Overload is in the little black box at the compressor...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Sep 10, 2010 | Magic Chef Refrigerators
Who manufactures Magic Chef refrigerators
google "magic chef" trademarks you may be supprised.(haier IS THE WORLDS LARGEST MANUFACTURER OF WHITE GOODS IN THE WORLD......MADE IN .......CHINA....)
tata make the worlds cheapest NEW car 1500 dollars
pre tax......made in india.
Jul 04, 2010 | Magic Chef CTB1821AR Top Freezer...
I have had my Magic Chef MCBR360S in my garage for about 2 years. Worked fine. Now it just stopped working. Any suggesstions?
Unplug and try connecting the thermostat wires together,if it comes on then replace the thermostat. If while unplugged remove the start relay and overload on the compressor. Shake around to see if anything shakes around inside re install and give that a try, Sea Breeze
Aug 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
Mcwc52b problem with cooling
I would try replaceing the overload/relay first . The piece that plugs onto the compressor . Without model number , cant give you the part number .
Jul 24, 2009 | Magic Chef MCWC45A Wine Cooler
Whirlpool start device
k here we go, thinkkn we can get this to work for you.
the difference is going to be the white overloads in the bag9s). depending on size of compressor they will change, as far a s the relay thinkin ther is onl one in that bag'box/ (brown with 3 possible connections..
if this is the cas e ill asume that the old relay/overload was a onepiece white plastic with smaller connectors.. .you will need to cut off and resplice a new spade connector on the wires to fiut the new piece..
the extras are just that extras, its easier for them to stock and store one part number for a multitude of repairs( youll need only one)
Mar 09, 2009 | Kenmore 50522 / 50524 Side by Side...
MY magic chef CTB1922 IS NOT COOLING
Sounds like your compressor overload tripping. Compressor may be stuck from sitting. Start relay may be stuck from sitting. Try a new start relay after making sure all your wires and connections are good. Sometimes a wrap with a deadblow hammer on the side of the compressor can get it going. Don't pound on it just a light wrap. My guess is the relay or overload first. Unplug before fooling with any wiring!
Jun 02, 2008 | Magic Chef CTB1922 Top Freezer...
Refrigerators Logo
257 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
