Question about Compaq Presario 5000 PC Desktop
My pc how can i upgrade? how can iup my virtual memory?
  • laya Dec 05, 2007
    how can i clean my registry for free
  • stevejohn Dec 07, 2007
    computer runnig slow, i defraged c&c but still the same-takeing a long time to start up
  • 108 Answers
Goto System Properties by right clicking My computer -> Advanced ->Performance ->settings ->Advanced and then you will see virtual memory, ideal to change it less than 2000MB.
Posted on Dec 05, 2007
My laptop keeps freezing its a dell latitude d610
If you are receiving virtual memory low errors then the first thing you should consider doing is upgrading your physical memory to prevent the use of virtual memory. You may also have too many applications running on the start up of your computer which will cause massive issues.
The D610 comes standard with 256mb of memory (unless you opt to upgrade at time of purchase). To upgrade this you may purchase memory by clicking here.
The above link is to newegg and using Kingston memory. This is reliable memory coming from a reliable distributor. I would suggest purchasing two of these chips to max your system out at 2GBs of memory (YOU MUST BUY 1GB CHIPS).
When you flip your laptop over there is a panel that should have an M or an icon that looks like a micro chip which you will remove. The memory banks will be under here. If you only see one under this panel then the other will be under the keyboard. To remove the keyboard you will find all the screws that are labeled with a K or a Keyboard icon then the Keyboard will lift off. Be careful not to disconnect the keyboard and just move it enough to install the memory (if you need to go under the keyboard at all).
This memory upgrade will resolve many of your memory related issues. If these issues do persist however then your computer may be overwhelmed at startup with various pieces of software launching and you will need your system optimized.
Nov 18, 2011 | Dell Computers & Internet
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
Upgrade memory for Compaq Presario R3000 PC Notebook
What OS are you running? 768 should be enough to run XP and keep you from getting that error message. On laptops their are normally just 2 slots for ram, so you would need to replace the 256 with the 512, which would bring you up to a gig of ram. Do you know if your computer has any spyware/adware on it? Sometimes malware can take up all your memory and generate just such an error. Do you know how many processes are running when you first login? Thank you.
Apr 10, 2009 | Compaq Presario R3000 Notebook
After loading service pack 2, my system is running much slower. memory 512. help
you need to increase your virtual memory (since you upgraded your service pack, most likely it will consume more ram)
from My Computer - Right Click > Properties
Then click on the Advanced Tab > Then click on perfomance settings
Then Click advance > Virtual Memory Settings
You can change it to say, 1000 (since you have 512 RAM ) to support the excess applications.
Let me know what happens.
Mar 17, 2009 | Dell Dimension 4550 PC Desktop
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
I get an icon saying low virtual memory. I recently upgraded to 1gig of memory. from 256 to 1 gig. what should i do?
hello ,
try this and you will get the answer,1759,2089076,00.asp
Sep 04, 2008 | Computers & Internet
To speed the computer
upgrade your RAM memory ..........(better not to use different frequency RAMS this decreases the performance) refer to your motherboard manual for this......
install the good antivirus & always keep the virus away ....
so by this you can speed up your pc...
if you are using the windows xp then increase the virtual memory ...
you make the virtual memory double of your RAM size ...
you can do that by going to
control panel>system>advanced>advanced>virtual memory settings> increase the size of the virtual memory for the drive where the OS is installed ....
any doubts reply me
i am always here to assist you
thank you
dnt forget to rate my solution
Jul 02, 2008 | Computers & Internet
Want to increase cache memmory .I am not sure where it is on motherboard or what type of memmory to order
L1 & L2 cache memory is actually on your CPU so it is not something you can upgrade.
If you are talking about Virtual Memory, that is different, as it is a file that resides on your Hard disk (not a memory chip at all) the size of your Virtual memory is allocated by your operating system. but is user customisable.
Apr 10, 2008 | Computers & Internet
How to increase my pc speed
You have to upgrade your RAM. 512MB is the minimum. Also you can increase the virtual memory. To do this right click on mycomputer, click properties, click on settings button that is next to performance, Click on virtual memory and then click on change. Set the value to 512. This will speed up your computer a little but stil upgrading your RAM is the best bet.
Feb 24, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
