Question about Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis mdg6400aww
My dryer is being tempermental sometimes it will work other times it won't. It is a gas dryer and sometimes the gas will ignite and other times it won't. The ignitor always glows it's just the gas sometimes doesn't come on. if i give the machine a tap it will work. Any suggestions?
    Problem Solver:
  • 9 Answers
You need to have the jets cleaned some times thy block up with dust
Posted on Dec 06, 2007
Where can i find replacement filter for MDG6400AWW
You could try your local appliance repair outlet or www.repairclinic.com. Hope this helps you.
Jan 21, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
My Maytag MDG6400AWW timer does not advance in the Auto mode. The clothes will dry but it will spin and spin for hours until you open the door. In timer mode everything appears to work normally
sounds like it is not sensing the temperature, which is the thermostat, here is a website that will help you out, #6 dryers basic, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 27, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Why does my Maytag Atlantis dryer not heat up at all?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 08, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Neptune mdg6400aww heats up for 1-2 mintutes then not heat
Make sure there are no major airflow obstructions. If not, replace the coil packs on the gas valve.
Aug 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
How do I replace the gas valve coils on my maytag atlantis gas dryer?
usually the gas valve is not the issue on these dryers after ten years of doing service calls i have only ever changed one. have you replaced the element that lights the gas? they have to see a certain resistance before they will open the gas valve. these will usually develop a hairline crack they will still glow red but not open the valve. when you replace it make sure you do not touch the element as this will shorten its life.
Apr 27, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Atlantis Gas Dryer mdg6400aww
i'm not sure but i think the screws are either a T-15 or T-20 security screw. TRy going to a really good hardware store to purchase the bits. As for your other problem it sounds as if it might be your door switch. After you get the machine open check for continuity.
Sep 01, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
300 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
