What is the cause for a non-working ice maker? The water is connected properly and continues to work but the ice maker just stopped working. I have removed everything from the refrigerator and the freezer and turned it off overnight just in case the water line was frozen but that did not fix the problem. I also changed the water filter and performed the basic troubleshooting steps with no success. I have not figured out how to remove the ice maker, which is my next step.
Pour about 2/3 cup of water into icemaker . If it freezes and dumps the cubes , replace the water valve ( the piece the wall waterline connects to on the fridge .). Also check the fill tube inside that fills the icemaker , to see if it is frozen solid . If so , then the water valve seeps and needs replaced . If the water freezes and does not dump , replace the icemaker . Check the coils below refrig , to make sure they are clean of dust , lint , pet hair , etc . An icemaker has to be 5 degrees to operate , and if the coils are not clean , that could bring the temp up to 6 or even higher .
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
