Back to:
Tags:
Pentax Optio 750Z Digital Camera
Pincushion and barrel distortion
By Chandler - usenet poster
My new camera (Pentax Optio 750Z) appears to have some noticeable
barrel distortion at wide angle and pincushion at telephoto.  I'm looking
for a useful filter to correct this.
I keep finding references to PTLens on the web, but they all point to
a 404 website.
Does anyone know how to get PTLens, or know a good way to correct
this kind of distortion without it?
I'm currently running the GIMP, 2.05, under Windows.
Thanks.
    Alan
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
kioner
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Great! Thanks for that. I might even use it myself!
David Hodson  --  this night wounds time
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Pincushion and barrel distortion:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Joey2
Rating: 0%, 0 votes
It uses pthreads? Oh, so it does...
Try commenting out all the pthread calls. I'm fairly certain that they
aren't needed - they were inherited from another use of the same code,
I think.
Thank You!
Solution #3
Not Rated (0)
Odud
Rating: 0%, 0 votes
This works.
http://schumaml.gmxhome.de/dow nloads/gimp/dbp-20040829.zip
HTH,
Michael
The GIMP > http://www.gimp.org      | IRC: irc://irc.gimp.org/gimp
    Wiki > http://wiki.gimp.org     | .de: http://gimpforum.de
Plug-ins > http://registry.gimp.org |
Thank You!
Solution #4
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
Thank You!
Solution #5
Not Rated (0)
man1
Rating: 0%, 0 votes
I tried. The preblem is the pthread stuff - there seems to be a port
of this for Win32 (http://sources.redhat.com/pthr eads-win32/). But
instead of adding another dependency, could this be rewritten using
gthreads?
Michael
Thank You!
Solution #6
Not Rated (0)
M0nica L
Rating: 0%, 0 votes
Thank you very much.
    Alan
Thank You!
Solution #7
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
http://schumaml.gmxhome.de/dow nloads/gimp/wideangle-20031211 .zip
No changes needed.
HTH,
Michael
Thank You!
Solution #8
Not Rated (0)
Hart
Rating: 0%, 0 votes
Very cool, thanks. Don't suppose you tried to compile DBP?
Thank You!
Solution #9
Not Rated (0)
Hart
Rating: 0%, 0 votes
There's also a plugin not based on panorama tools, at:
http://members.ozemail.com.au/ ~hodsond/wideangleSrc-11-Dec-2 003.tgz
But I haven't compiled it on Windows, so I don't know whether
it will need any changes.
Thank You!
Solution #10
Not Rated (0)
Duke
Rating: 0%, 0 votes
Thanks Leonard,
I found a panotools plugin for gimp 1.2, but couldn't find one for 2.0
(for Windows anyway).  Then I found a pspi.exe for Gimp 2, figured
out how to use it, and tried the Photoshop PTLens plugin.  No luck yet,
but I'm still working on it.
I also found source code for twist and wideangle, two plugins that
supposedly handle pincushion and barrel, but haven't yet tracked
down any binaries.  I could try setting up an environment for
compiling them, but I don't have the heart for that right now.  I've
got the free Borland C++ compiler on my machine, but haven't got
the Microsoft compiler at the moment and know I'd have to go through
some hoops to get GTK, Gimp, and whatever else working before
I'd even be ready to start on twist and wideangle.
Lest you Linux guys think that you have all the configuration fun
and us Windows users don't get any of the challenge of getting
software to work - don't be too sure of it.  We get plenty of fun too.
I spent 5 hours Wednesday getting my new Epson scanner to
install under Windows XP before I finally discovered and corrected
some registry errors on my system to get it working.
But I guess that beats the 20+ hours I spent (before giving up) trying
to get my Linux dual boot to recognize my wireless network card.
Computers are such a hoot.
    Alan
Thank You!
Solution #11
Not Rated (0)
Luisa_K
Rating: 0%, 0 votes
Thanks Gerald.
I discovered the problem with the PTLens website is that it has
exceeded the allowed number of downloads per month.  It may
be available later, or maybe some kind soul will rehost the
software for the author.
It appears that the GIMP plugin registry has twist and wideangle,
that website seems to have problems too at the moment.  But
I'll get them eventually.
     Alan
Thank You!
Solution #12
Not Rated (0)
maartenw
Rating: 0%, 0 votes
I've just been to the PTLens site now and downloaded the plug-in without any
problems at all...maybe a good time to try again quick, Alan :)
Kline
Thank You!
Solution #13
Not Rated (0)
kioner
Rating: 0%, 0 votes
I got into the site and downloaded the software.  It took a few minutes
to figure it out and add my Pentax Optio 750Z to the pentax_profile (it
seems to have the same lens as the Optio 450/550/555 and so can use the
same profile), and try it out.
I don't have Photoshop and therefore couldn't use the fast Photoshop
plugin version.  But the stand-alone version, although a bit slow (22
seconds on my Athlon 2600+,  38 seconds on a 2.26 GHz Pentium 4, both
for a 7mp image), it works great.
    Alan
Thank You!
Solution #14
Not Rated (0)
paulrmc
Rating: 0%, 0 votes
There is a gimp plugin for correcting barrel and pincushion distortion.
   It is based on panorama tools.  I had to do some searching to find it
in the first place, and unfortunately I didn't keep a record of where it
is.  But it should not be too hard to find with google.   It works quite
well once you figure out how to use it, and it is very simple to use.
Thank You!
Solution #15
Not Rated (0)
Beresford
Rating: 0%, 0 votes
Look for plugins ??twist?? and/or ??wideangle??
Gerald Hammer
Thank You!
Can you Help with these Digital Cameras problems?
My 750z got splashed with water today. It was in it's...
The display shows card locked and I can't unlock it
My camera will only power on in the menu mode, sorry for...
I have had this camera for a while and now the screen has...
I recently sent my Pentax Optio 750Z Digital in for...
Loading problems.
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
