Remove the food and icemaker (if it has one) . Remove all the screws holding the rear panel on and remove the rear panel . Using a hair dryer , start in the middle below the coils , and defrost until you see the drain hole . Keep defrosting the hole , sometimes hot water helps , until water starts to go down . Use a small hose inserted into the hole , and blow thru to blow out any debris collected in the drain tube . Get a piece of ALUMINUM wire , stripped of insulation (14-16 guage ) and put as far into the drain hole as it will go without any force . Sometimes bending slightly will help it go farther . Wrap the other end 1 or 2 turns around the black rod ( defrost heater ) above the hole . When refrig goes into defrost , the heater will transfer heat to the aluminum wire , keeping the drain from freezing again . Reinstall the back panel and icemaker ( if equiped ) and the food .
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
