Back to:
Tags:
Air Conditioners
Generic problem for all Air Conditioners
Carrier rooftop unit (by 2 users)
posted by paulka on Dec 05, 2007
fan runs but the heat will cycle once and then stop, checked and replaced the ignitor and servised the unit, what's up
Comment by paulka, posted on Dec 06, 2007
it was a roof top carrier unit for heating and ac model number as follows 48HJR014-56185 tried a hot suface ignitor but problem still there
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Oct 09, 2008
need to find a way to support a 10 ton RTU on a steel joist roof. wt = 925#
Solution #1
posted on Dec 07, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
figured it out, the problem was return air ducting was capped off, by the construction crew, thanks
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on carrier rooftop unit:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Therinnaiguy
Rank:Guru Guru
Rating: 87%, 209 votes
A model number may help. Also, are you refering to the inducer fan?
If so, jump out the pressure switch. If it runs, start looking for a blockage in the combustion chamber, blockage in the line to the pressure switch, a bad inducer fan (not getting enough pressure to close switch) or a bad pressure switch.
Comment by Therinnaiguy, posted on Dec 06, 2007
OK, check out the things I suggested and get back to me.
Thank You!
Can you Help with these Air Conditioners problems?
Air Conditioners
i have a ideal mini c24 cobi boiler and it isnt holding...
Dometic Rooftop RV Air Conditioner
heat pump side not working cools ok
Danby DPAC10061 Air Conditioner
My AC unit blue indicator light flashes continually. The...
Air Conditioners
On a aquastar 125 vp, after the water is turned off on any...
Air Conditioners
My 2005 Dometic travel trailer fridge/freezer works...
Loading problems.
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
