Question about Toshiba 20DL74 20 in. EDTV-Ready LCD Television
TV loses all power
TV goes blank and the blue active indicator light goes dead. Not the normal red indicator for when the set is just turned off. This happens every time the set is used after about 45 minutes. Have checked and the menu indicates that we are not using sleep mode. The set's plug has to be removed from the outlet for about five minutes and then plugged back in. When it is plugged back in the blue light returns and the set operates totally normally. This problem is driving us nuts. Any help or suggestions greatly appreciated.
  • 1 more comment
  • Doug Dec 26, 2007
    We have exactly the same problem and Toshiba offers no help. Could it be the power adapter?
    douggell
    dgellatly@sympatico.ca
  • Anonymous Jan 18, 2008
    same problem but mine wont turn back on after it goes out....completely dead and i know nothing is broken...maybe a fuse????
  • Anonymous Mar 12, 2014
    while playing a recording that i was re-recording the power went out for a few minutes. when power came back on after a few minutes, the list of items on the hard drive was gone but the gigabytes used seems to indicate that the data is still there. any solutions would be appreciated
I had same problem. Finally figured out the power supply was the problem. I ordered a generic replacement and it hasn't shut off again for over a year. The only thing I have notice is there are noise lines in the lower channels (1-6). This may be beause the Toshiba power supply may have a noise filter in the power supply. But the generic was $30 compared to $80 Toshiba
Posted on Apr 03, 2008
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Inoperative LCD TV
Welcome to Fixya! My Name is Travis! I have heard this Problem Before on Another Model. Turns out it was the Power Switch in that case. Yours has the Exact same Symptoms. Get that Checked and let me Know so we can go Further or if that is it.
Jan 02, 2009 | Televison & Video
MITSUBISHI CRT TV MODEL CT-33AC2SL
check for dry joints in power supply
Oct 09, 2007 | Televison & Video
Toshiba 20DL74 20 in. EDTV-Ready LCD Television Logo
359 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
