Question about Refrigerators
Broken amana refrigerator wheels
I need to replace the front left leveling wheel ( which I think I know how to remove).
How do you remove the rear moving wheel.It appears that the axle is constructed into a permanent frame. The roller split in two and has fallen off.
Thanks, Ed
  • Anonymous Mar 14, 2014
    I have replace a broken crisp frame, however could not find a center support for this frame in the rear of the fridge, there are only two supports on the left and right rear Appears in sears direct as:" Crisper frame mount for Amana Amana refrigeration model #XRBR206BB0
    PART NUMBER: 67001716" can you please let me know if there is any center support for the frame
  • 100 Answers
Usually the roller for the rear of the fridge has an axle that is just a pin that will slide out(need a model # to know for sure) and the weight of the fridge holds the pin in place.
Posted on Dec 05, 2007
How do I level my fridge?
It is rare that the rear wheels adjust. Most of the adjustment is in the front wheels. They sometimes put screw jacks in the front as well.
Jul 24, 2014 | Kenmore Refrigerators
How do i lower the rear wheels? The back end sits flat on the floor but the front is raised higher because the nylon wheels are fully retracted. I will also need to level out the fridge.
set the level that backside of the fridge must be lower than front side,so that doors may,must be closed automatically after open the fridge
Jul 08, 2014 | Amana ASD2620HRW
Level a refrigerator
Rinda,
Most refrigerators will have a leveling leg or wheel at each ot the front corners. What I usually do is lift the refrigerator up and set a block under the refrigerator and turn the legs or the screw for the wheels until they are at the point I want them and then remove the block. In your case, if you have leveling legs you will want to screw them into the refrigerator to lower the front. If you have wheels you will need a screwdriver or a nut driver and un-screw the bolt to lower the front. You may need to take the trim under the door off to access the bolts if you have wheels in the front. Hope this helps!
Jun 04, 2013 | Refrigerators
I downloaded the manual for this unit and it says to adjust the front leveling wheels to bring it to level. I removed the grill and looked for the adjustment screw...there is none. shimming is not an...
Front wheels should screw in and out for adjustment purposes!!!!!!!!!!!! And with that degree of tilt you might just have to resort to shimming so be ready.
Aug 27, 2017 | Amana ATB1932MR Top Freezer Refrigerator
Amana arb2217csl is there a leveling adjustment for the back wheels?
Yes typically the rear wheels can be raised/lowered by adjusting the screws as shown in this link,
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CSLPARB2217CS2/1268/0161000/M0403273/00006?blt=06&prst=&shdMod=
item#29 is what ya turn to adjust the rear wheels,open that link then click view full size again to see where they are
Aug 22, 2011 | Refrigerators
How do level out the upper doors on the Amana bottom freezer French Door refrigerator?
The ref is not usually at fault your floor is uneven.
Shim either the left or right rear wheel 1/4' at a time.
This will take the twist out of the box and Lvl. the doors.
Use hard board avail at Home depot.
2x4' sheet and have them cut it into 3 8" strips
then have hem cut one into 4 12' rectangles.
Use the long pices to roll your ref. out onto so you protect your floor.
Use the small ones to shim the rear wheel.
Jan 15, 2010 | Amana AFD2535FE Bottom Freezer French Door...
How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
May 02, 2009 | Amana ATB2132ARQ 33" Top Freezer...
KitchenAid Superba humming
First to adjust the leveler/wheels you will need to remove the front grill/toe plate. On the left and right sides you should see some bolt heads that are about 1/2" hex head. One on the left adjust the rear leveler/wheel and the other on the left adjust the front leveler/wheel. Turn the hexhead clockwise to raise cabinet higher counterclockwise to lower cabinet. The right side is the same.
Now to your noise, it sounds like you may have pushed the cardboard air dam under the condenser and condenser fan motor near the compressor up into the fan blade area. Carefully follow the source of the sound and you will find what is out of its proper position.
I hope I helped, supertechks
Nov 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
694 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
