Question about Kenmore Oasis 27042 Top Load Washer
Error Code F50
Hi I have the Kenmore ELITE Oasis HE. I am recieving the error code F50 and I would like to try and solve this myself. I saw a post about code F51. Is this in any relation to the F50? And if so how do i access the harness they are talking about.
Much thanks,
Chris
  • Anonymous Jan 30, 2008
    I'm getting Error Code F51
  • nbaker2005 Sep 14, 2008
    Also received the code 50 fault. Performed the diagnostic tests in auto and manual and machine still would not spin. Performed troubleshooting test #3 and and found nothing wrong. Test procedure then tells you to replace the RPS board. I have just completed that replacement and I can't get it to go into the diagnostic modes or power on. The manual now leads you to T/S test #1. The machine is receiving power because you can hear it cycle a small amount of water into the machine. Both Test #1 and #3 are now telling me replace the motor control assembly. Is this really the problem or am I going to have to purchase something else?
Stop buying sears appliances!!!! NEVER again!!!
Posted on May 16, 2012
After only 2 years & 2 months I had the F50 code too. I hadn't bought the extended warranty as we were buying 3 big appliances. I figured odds were that all 3 would last at least 5 years & if 1 out of the 3 did break it would be cheaper to buy a new one than having to pay warranties on 3 appliances at the point of sale. Anyway, I seriously considered just buying a brand new washer since this model does seem to have serious issues after I did some research on the internet. It would cost $75 just to have a Sears repairman give an estimate & I knew the parts would be at least $200. I'd rather put that $ toward a new washer. I figured I'd call Sears to complain that even though I didn't have a warranty, this expensive model seemed to have a very poor reputation & maybe they'd help me out. No freebie fix-it offer but I was told that I could buy a 1-year service contract or $215 +tax. I called 888-528-6326 & bought it. A repairman came out & had to order parts so he set up the actual repair for a week later. He was very helpful & pro-active. He replaced the part that was broken & also replaced the entire top circuit panel with an upgraded version. I guess he figured that it would break eventually too. So now I'm covered for the next year...hopefully with the upgraded parts this machine will last a lot longer. If I get another 5 years out of I'll be very happy. It really does do a fantastic job cleaning clothes.
Posted on Jul 29, 2009
F50CODE IS COMING ON AFTER 20 SECONDS ON EVERY CYCLE
Posted on Jul 12, 2009
  • 117 Answers
The most common fix is to replace the speed sensor, but sometimes it just need to be clean. but you can try to lay down the washer and take the magnetic motor out and you gonna see the speed sensor connect to the motor, take that out and unplug the wires than cleaning the connections, just do a little scratches at the speed board connection, that should work.
I do that almost every day and I never came back to the same house
Posted on May 10, 2008
I’m still working on my washer so this is not a success story. I was getting the F51 code and I found that the RPS circuit board was burned up (I could clearly see the fried components). I also found two of the wires smashed with the wires exposed, so I taped them up. I ordered a replacement RPS sensor and installed it today. No more F51 code, but now I’m getting a F50 code. So I took everything apart looking for anything that would stop the drum from turning. While I doing so, I found the “Service Manual” in a plastic bag stuck on the front inside wall of the washer. If your not scared to take things apart you’ll want to take a look at this manual. To get it you will need to take off the top cover of the washer (remove the two hinges at the back then pull the top towards you about an inch then raise the top. Don’t break the wire at the back) you should then see the plastic bag with the service manual inside. Hope this saves someone a few hours of troubleshooting. Looks like I've got to replace the motor in my unit.
F50 = Motor Stalled
F51 = RPS Failure
F52 = Motor Stop Failure
F53 = Motor Control Overtemp
F54 = Motor control Overcurrent
    Problem Solver:
  • 3 Answers
You are not going to believe this but I had the feared F-51 code on my machine and after doing a ton of electrical troubleshooting and part replacement........the problem was a pair of Boxers jammed in between the walls of the drums!!!!!! REMEMBER.....
LOOK FOR THE SIMPLE THINGS FIRST!!!!!! DONT MAKE A MOUNTAIN OUT OF A MOLE HILL!!!!!
Catriver is gonna love this one!!!
Posted on May 04, 2008
My Kenmore Elite Oasis HE is flashing a code "F50", can you tell me what the error code means?
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Oct 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Hello, I have a Kenmore Elite Oasis 110.27062603 washer that is displaying error code F 50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 11, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore elite oasis washer model # 110.2703 shows code F-50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 25, 2010 | Kenmore Oasis 27042 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer won't start spin cycle, error f50
The F50 error on the Whirlpool Cabrio / Kenmore Oasis points to the basket and possibly some obstruction keeping it from turning freely.
Please see the following PDF Service Manual for the Whirlpool.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F50 alarm on my kenmore oasis washer
Sep 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis he top load washing machine f 50 code
Aug 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE top loading washer model #110.27082602 gives me error code F50 and doesn't spin. Other blogs tell me that it is possibly a main control board. What do you think?
Mar 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Ellite Oasis - model #27042603
Jun 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
KENMORE ELITE 2709
Dec 29, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis 27042 Top Load Washer Logo
973 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
