How do you set timing without being able to turn crank and cams at the same time to align. Do you remove cams or just turn to align????
Remove the #1 sparkplug place a long screwdriver in the sparkplug hole point touching the top of the piston turn the crankshaft around until the screwdriver is almost pushed out (top dead center)
check to see that the distributor rotor is pointing at the #1 sparkplug wire it must be; if not: turn the crankshaft again until it does
then turn the camshaft around until both valves above the #1 piston cylinder are closed
this is correct; now find the marks on the belt camshaft sprocket gear and, crankshaft gear aline the belt marks with the gear marks and, install the belt
Testimonial: "Will test this weekend. Thanks for info. Old school not used to OHV system"
