Question about Dacor ECS127 Epicure Stainless Steel Electric Single Oven
LED FRROZEN While cooking, the LED display is frozen and says 0 degrees and pushing the buttons do nothing
  • 833 Answers
Sounds like you have a need for a circuit board. First, disconnect power for a few minutes and re-power. If that doesn't fix it, get a new board. Turn off power before working on your unit.
Posted on Dec 07, 2007
Need to know the cooking time and temp in C in fan forced oven for pork loin roll weighing 1.22kg
usually 40 minutes per 500 grams at 180 degrees C
so 1 and a half hours plus preheat the oven .
And it is thawed not frozen
don't just take my word for it read it on link below
Dec 24, 2016 | Ovens
I have a double electric creda oven and i have just had the house re wired. becasue the power has been off the oven is flashing on the display at 0:00 auto and i cannot switch my main oven on as when i...
While holding minute minder and cook period buttons press + or - to set the time after time is set release buttons this should allow for normal operation
May 27, 2014 | Creda Ovens
Oven temperature is offf by 30 degrees
It does vary some by model yet the control can usually be calibratied by;
Pushing and holding the BAKE button until the tempature that is displayed changes to 00 then push the up/down arrows to adjust the temp. +/- up to 35 degrees once ya have selected the ajustment all be it up, or down 30 degrees push the cancel/off button and the change will be saved
Oct 02, 2011 | Maytag Ovens
I press the bake button, i choose temp Ie:350 degrees, wait until goes up to temp, next thing you know, it shows 350 but the food is not cooking. press cancel, press bake and 350, temp starts to climb from...
More information is required make model, display type LED, or blue neon red light goes out when on temp, without more info cannot help.
May 17, 2011 | Ovens
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
Kitchenaid KEMS308 display is saying "enter probe temp or remove probe" No probe is plugged in or has been used in a while. This message came up after cooking for about 3 1/2 hours at 300 degrees. Now...
Apparently this is to do with moisture having affected the oven adversely (I got this error message after baking 50 potatoes with all the steam that generated. Have a look at this page ....the solution is to set the probe for 160F then turn the oven on for 15 minutes or so at 450F. This apparently should dry out the probe position and all work again.....I am trying it now.....
Sep 07, 2009 | KitchenAid Architect® KEMS308SSS Stainless...
KEMC308 has frozen, unusual looking display info. Nothing works.
Try unplugging it or flipping the breaker to the oven. Leave the power off to it for a minute, then turn it back on.
Mar 27, 2009 | KitchenAid KEMC308 Electric Double Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Kenmore oven does not seem to be turning off.
if the broil element was on and the door closed then the oven may have encountered an over temperature issue. i would need your model number and the error code
Nov 26, 2008 | Ovens
Dacor ECS127 Epicure Stainless Steel Electric Single Oven Logo
82 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
Are you a Dacor Oven Expert? Answer questions, earn points and help others
