The JBP78 is electric, since you are talking about a gas oven I think the model is incorrect.
Talking about a gas ovens:
If the oven is not heating up and both broiling and baking burners are working and coming up then check the temperature probe sensor and the control board.
If one of the two burners is not firing check the ignitor, the burner and coil, the burner and flame sensor. The most common problems come from defective ignitor.
Did you hear a "pop" or smell like something was burning? Sounds like old oven could have been 3 phase, and you new oven single phase, Check the power requirements for oven and see what kind of power you are supplying it with.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
